Hi All,
I can’t seem to get audio from my IC-R8600 to my Mac. One of them is an M1 Macbook Pro with 12.6, and the other is an older Intel iMac with 10.13. The iMac audio is fine when I boot to Windows 7, but nothing on OSX. My Macbook pro has fine audio, if I connect a USB cable to the radio (WFView config for Network connection), but nothing without the cable. I have tried QT, Port Audio (crashes app), and RT. My laptop did receive audio once, but stopped without changing any settings. I can upload logs.
I am using Macbook Pro Speakers and Microphone. My only other choice is MS Teams audio. Perhaps I didn’t explain myself well. I tried the USB cable while the Radio Connection was set to Network. Audio worked when connected in this way. I have no plans to use a USB connection.
When you connect the USB cable you can use the radio audio directly, such as in fldigi. But it has no bearing on hearing the radio sound through your speakers. It may have worked due to coincidence or some odd unintended behavior.
Anyway,
Can you select your Mac speaker and mic, change to “QT Audio”, Save Settings, and then close wfview? Next open wfview. If you have any audio trouble, press “Log” and then press “send to termbin”. It will present you with a URL in a few seconds, which you can then paste into your reply here. Then we can take a look and maybe figure something out. There are some interesting subtle audio issues we run into sometimes with device selection, for example.
There is an issue that can cause wfview to not select audio devices if they are the only device on the system. If you have a USB headset or other similar audio device, can you try using that instead?
We will hopefully be releasing a version that fixes this issue soon.
Make sure you plug the headset in prior to opening wfview. Next, when wfview is opened, press “Disconnect”. Now head over to Settings and Radio Access, and select the USB headset. Press “Connect”. If it works, press “Save Settings”.
It works ok when I plug in an external sound card, and plug my headphones into it. I was hoping there may be a beta fix so I don’t have to use an external sound card.
I think @phil is planning to rework a lot of the audio device selection code. It’s quite tricky, and all three platforms need some help. I don’t know what timeline there is on that fix, and it’ll of course also depend upon how difficult it ends up being one we get into it.
