The audio device will not be found
2022-12-20 11:25:48.683 INF audio: Input No audio device was found. You probably need to install libqt5multimedia-plugins.
So, I can change the codec but no audio.
if I install eqmac ,then will be found that device an I have audio but no microphone.
in the log is standing: I need to install: libqt5multimedia-plugins
but I don’t work with linux
Once done, you need to select the other audio device and then select your ‘actual’ audio device, then save settings. This will be fixed in the next release.
so, it’s working.
I saw at my old MacBook, that if got drivers from an other software for the audio device.
sunflower (2ch) I download them on my newer MacBook and in the setting I set on RT audio.
Under audio output I have now: apple inc. and under input ma++ in galls
now, it’s working. I can hear and send with good audio
I hope I can help with this instruction and you can understand my English
