Loaded 1.2d, no communication with 7300 via USB, so went back to 1.2c, still can’t communicate 7300-to-wfview. Have gone through set-up several times, no joy. osx 10.13.6
Hi KMac,
Can you share with us your log file? Maybe we can figure out what’s going on there. On macOS, it is located:
~/Downloads/wfview.log
2021-12-17 15:34:12.061 INF system: “Starting wfview: build 21bc02c on Sep 7 2021 at 20:44:22 by phil@Phils-MacBook-Pro-3.local”
2021-12-17 15:34:12.061 INF system: “Operating System: macOS High Sierra (10.13) (x86_64)”
2021-12-17 15:34:12.061 INF system: “Build Qt Version 5.15.2. Current Qt Version: 5.15.2”
2021-12-17 15:34:13.783 WRN qt.qpa.fonts: Populating font family aliases took 1144 ms. Replace uses of missing font family “DejaVu Sans” with one that exists to avoid this cost.
2021-12-17 15:34:13.934 INF default: setState 1
2021-12-17 15:34:13.935 INF default: setState 0
2021-12-17 15:34:13.936 INF default: setState 1
2021-12-17 15:34:14.038 INF system: Loading settings from “/Users/kelly/Library/Containers/org.wfview.wfview/Data/Library/Preferences/org.wfview.wfview.plist”
2021-12-17 15:34:14.044 INF rigctld: started on port 4533
2021-12-17 15:34:14.044 INF gui: Got Audio Output: “Built-in Output”
2021-12-17 15:34:14.044 INF gui: Got Audio Input: “Built-in Input”
2021-12-17 15:34:14.047 INF default: Getting server config
2021-12-17 15:34:14.105 INF system: Cannot prepare WF view without rigCaps. Waiting on this.
2021-12-17 15:34:14.139 INF serial: Opened port: “/dev/tty.SLAB_USBtoUART”
2021-12-17 15:34:14.140 INF serial: Opened pt device: 19 , attempting to grant pt status
2021-12-17 15:34:14.140 INF serial: Opened pseudoterminal, slave name : /dev/ttys000
2021-12-17 15:34:14.140 INF serial: Created link to “/dev/ttys000” from “/Users/kelly/Library/Containers/org.wfview.wfview/Data/Downloads/rig-pty1”
2021-12-17 15:34:14.271 INF system: Received CommReady!!
2021-12-17 15:34:14.271 INF system: Delay command interval timing: 75 ms
2021-12-17 15:34:14.271 INF default: Setting rig state
2021-12-17 15:35:23.224 INF system: Saving settings to “/Users/kelly/Library/Containers/org.wfview.wfview/Data/Library/Preferences/org.wfview.wfview.plist”
Hi KMac,
Do you have any other USB serial-like devices connected? Any other ham radio programs running?
The log file seems to indicate that the radio’s serial port was opened.
USB mouse, that’s all.
Hi KMac,
Try debug logging and see if we get any more clues.
cd /Applications
open wfview.app --args --debug
Once you launch wfview like that, the log file will fill with a bit more information.
You might also try a full power cycle on the radio, prior to opening wfview.
Verbose logging?
You mean power down, disconnect the 12 volt external power supply, wait 5 minutes, then reverse, lastly launching wfview?
wfview.log (169.4 KB)
2021-12-18 18:14:24.648 INF serial: Could not open serial port “/dev/tty.SLAB_USBtoUART” , please restart.
did you restart the machine that always works?
Yes, however, I did not reset SMC. Will try that today.
n00bie error…I had changed CI-V USB Port to Lin to REMOTE. All is well now…tnx, 73.
