Hello Wfview dev team,
First of all let me say a big THANK YOU for this software. It is a awesome to have computer based GUI rig control and a waterfall on a linux system. I have downloaded and installed Wfview on my Ubuntu 22.04 OS and connected it to my IC7300 via USB. I am able to see the waterfall and change frequencies as well as trigger transmit and tune on the desktop. I would like the audio to come through my desktop speakers instead of the rig and be able to use my computer USB mic to transmit. The secondary Meter Selection is set to TxRxAudio and I am not seeing any activity on receive or transmit. I have the USB audio/mic gain to mid on the GUI view and there is still no audio activity during receive or attempted transmit. The audio devices I am using are the same I use for WSJTX with the exception of the Logitech USB audio input and the settings work well in WSJTX. Radio settings Mod input is set to USB. My log file output is below. Any advice would be appreciated…
Thank you and 73 - Marc N9WIB
2022-12-03 11:04:24.477 INF system: “wfview version: 1.53 (Git:9367d60 on Nov 30 2022 at 16:44:56 by marc@mab-core)\nOperating System: Ubuntu 22.04.1 LTS (x86_64)\nBuild Qt Version 5.15.3. Current Qt Version: 5.15.3\n”
2022-12-03 11:04:24.490 INF default: setState 1
2022-12-03 11:04:24.490 INF default: setState 0
2022-12-03 11:04:24.506 INF system: Loading settings from “/home/marc/.config/wfview/wfview.conf”
2022-12-03 11:04:24.545 INF rigctld: started on port 4533
2022-12-03 11:04:24.545 INF gui: Got Audio Output from Settings: “alsa_output.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.analog-stereo”
2022-12-03 11:04:24.545 INF gui: Got Audio Input from Settings: “alsa_input.usb-046d_Logitech_Webcam_C925e_C8CC2BAF-02.iec958-stereo”
2022-12-03 11:04:27.783 INF gui: Found Audio Input Device: “alsa_input.usb-046d_Logitech_Webcam_C925e_C8CC2BAF-02.iec958-stereo”
2022-12-03 11:04:27.783 INF gui: Found Audio Output Device: “alsa_output.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.analog-stereo”
2022-12-03 11:04:27.783 INF gui: Got Server Audio Input: “alsa_input.usb-046d_Logitech_Webcam_C925e_C8CC2BAF-02.iec958-stereo”
2022-12-03 11:04:27.783 INF gui: Got Server Audio Output: “alsa_output.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.analog-stereo”
2022-12-03 11:04:27.949 INF system: Cannot prepare WF view without rigCaps. Waiting on this.
2022-12-03 11:04:27.954 INF rig: creating instance of rigCommander()
2022-12-03 11:04:27.955 INF cluster: starting dxClusterClient()
2022-12-03 11:04:27.955 INF udp.server: Starting udp server
2022-12-03 11:04:27.955 INF audio: Audio Input device “alsa_input.usb-046d_Logitech_Webcam_C925e_C8CC2BAF-02.iec958-stereo”
2022-12-03 11:04:27.955 INF audio: Audio Output device “alsa_output.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.analog-stereo”
2022-12-03 11:04:27.957 INF udp.server: My IP Address: “0.0.0.0”
2022-12-03 11:04:27.957 INF udp.server: Server Binding Control to: 50001
2022-12-03 11:04:27.957 INF udp.server: Server Binding CIV to: 50002
2022-12-03 11:04:27.957 INF udp.server: Server Binding Audio to: 50003
2022-12-03 11:04:27.960 INF serial: Opened port: “/dev/ttyUSB0”
2022-12-03 11:04:28.025 INF system: Received CommReady!!
2022-12-03 11:04:28.025 INF system: Delay command interval timing: 75 ms
2022-12-03 11:04:28.026 INF default: Setting rig state for wfmain
2022-12-03 11:04:28.029 INF rig: Using incomingCIVAddr: (int): 148 hex: “0x94”
2022-12-03 11:04:28.029 INF serial: Received rigCapabilities for “IC-7300”
2022-12-03 11:04:28.029 INF rig: Have rig ID: decimal: 148
2022-12-03 11:04:28.047 INF rigctld: Got rigcaps for: “IC-7300”
2022-12-03 11:04:28.052 INF system: Delay command interval timing: 25 ms
2022-12-03 11:04:29.697 INF rig: Received 0x15 center span data: for frequency 250000
