I have been able to connect and operate all functions on a remote laptop at my home and I can receive audio fine and transmit. When at another location though I can connect and see the waterfall and all controls seem to work but I have no receive audio. My setup is: remote laptop Win10 client and Win11 server connected USB to Icom 7300. I have tried all the audio settings without result.
Truncated log:
023-01-08 15:43:57.504 INF udp: udpHandler Received radio capabilities, Name: IC-7300 Audio: ICOM_VAUDIO CIV: “0x94” MAC: 0 : 144 : 199 : 70 : 48 : 58 CAPF 20481
2023-01-08 15:43:57.504 INF udp: Got Connection status for: IC-7300 Busy: 0 Computer IP “0.0.0.0”
2023-01-08 15:43:57.504 INF udp: Got Radio 0
2023-01-08 15:43:57.504 INF udp: Find available local ports
2023-01-08 15:43:57.504 INF default: Received serial port baud rate from remote server: 115200
2023-01-08 15:43:57.504 INF system: Delay command interval timing: 75 ms
2023-01-08 15:43:57.551 INF udp: Starting udpCivData
2023-01-08 15:43:57.551 INF udp: UDP Stream bound to local port: 62450 remote port: 50002
2023-01-08 15:43:57.551 INF udp: Starting udpAudio
2023-01-08 15:43:57.551 INF udp: UDP Stream bound to local port: 62451 remote port: 50003
2023-01-08 15:43:57.551 INF udp: udpHandler Got serial and audio request success, device name: “IC-7300”
2023-01-08 15:43:57.551 INF udp: Got Connection status for: IC-7300 Busy: 1 Computer Bob-PC-wfview IP “64.229.186.223”
2023-01-08 15:43:57.551 INF audio: Output audio handler starting: “Realtek Digital Output (Realtek High Definition Audio)”
2023-01-08 15:43:57.551 INF audio: Output No audio device was found. You probably need to install libqt5multimedia-plugins.
2023-01-08 15:43:57.551 INF audio: Input audio handler starting: “Microphone (USB Audio Device)”
2023-01-08 15:43:57.551 INF audio: Input No audio device was found. You probably need to install libqt5multimedia-plugins.
2023-01-08 15:43:57.589 INF udp: udpCivData : Received I am here
2023-01-08 15:43:57.589 INF udp: udpAudio : Received I am here
2023-01-08 15:43:59.572 INF udp: Audio Watchdog: no audio data received for 2s, restart required?
2023-01-08 15:44:03.120 INF udp: CIV Watchdog: no CIV data received for 2s, requesting data start.
2023-01-08 15:44:06.662 INF rig: Using incomingCIVAddr: (int): 148 hex: “0x94”
2023-01-08 15:44:06.662 INF serial: Received rigCapabilities for “IC-7300”
2023-01-08 15:44:06.662 INF rig: Have rig ID: decimal: 148
2023-01-08 15:44:06.662 INF system: Delay command interval timing: 25 ms
2023-01-08 15:44:07.411 INF udp: udpCivData 1 or more missing packets detected, previous: “0xcd” current: “0xd0”
2023-01-08 15:44:07.433 INF udp: udpCivData : sending request for multiple missing packets : “ce:00:ce:00:cf:00:cf:00”
2023-01-08 15:44:07.464 INF udp: udpCivData : Missing SEQ has been received! “0xce”
2023-01-08 15:44:07.464 INF udp: udpCivData : Missing SEQ has been received! “0xcf”
2023-01-08 15:44:09.037 INF rig: Received 0x15 center span data: for frequency 100000
2023-01-08 15:44:25.746 INF udp: udpCivData 1 or more missing packets detected, previous: “0x828” current: “0x82a”
2023-01-08 15:44:25.815 INF udp: udpCivData : sending request for missing packet : “0x829”
2023-01-08 15:44:25.831 INF udp: udpHandler 1 or more missing packets detected, previous: “0x105” current: “0x107”
2023-01-08 15:44:25.862 INF udp: udpCivData : Missing SEQ has been received! “0x829”
