No remote connection both sides
Hello dear, i used Wfview for test long time ago, now im more interested in remote op with 7300.
To the local computer (with the radio connected with usb) i have no problem. i setted the radio following this guide 7300 setup - Google Slides
I decided to run the server mode, using 50001 50002 50003, and create a user with password. on the laptop always in my LAN, i set up radio as network, with server ip, port 50001 and user and pass login.
It seen that client cant connect to server, i dont see any problem in log, i tried to restart everything, using different ports, different users but nothing.
I decided to try the reverse (using laptop as server with radio USB and desktop as client) and still not working.
I already checked both computer on windows firewall persmission.
Any ideas? maybe wrong configuration on radio? should the server be “connected to radio” or not ? ( i tried both) thank you guys!
The radio must be connected to the “server” wfview computer (otherwise it has no way to share the connection).
Almost always, this kind of issue is related to incorrect configuration, most likely firewall settings or some other software blocking access to UDP (not TCP) ports 50001-50003. Please read through the manual, specifically the sections on server setup.
