Server is win10, wfview 12.e,station ic-7300, communication fiber to internet.
Client is Macbook Air monterey 12.5 and Processor M1 ,16GB memory. and wfview is version 12.e using port 60001,60002 and 60003. 60001 as control. Open in Firewall for traffic over internet and pointing to correct ip-adress (ip-to my server in my LAN). When I changed to Mac as client I lost the connection (rx latency 577 ms) and red in color. Not moving up/down.No sound from the client. Is there a problem with port 60003(audio) ? or how can I test to see what is the problem?
Check the log file on the client.
2022-08-29 14:24:29.953 INF system: “wfview version: 1.2e (Git:227ea8f on May 24 2022 at 16:19:23 by phil@Phils-MacBook-Pro-3.local)\nOperating System: macOS 12.5 (arm64)\nBuild Qt Version 5.15.2. Current Qt Version: 5.15.2\n”
2022-08-29 14:24:30.241 WRN qt.qpa.fonts: Populating font family aliases took 199 ms. Replace uses of missing font family “DejaVu Sans” with one that exists to avoid this cost.
2022-08-29 14:24:30.273 INF default: setState 1
2022-08-29 14:24:30.273 INF default: setState 0
2022-08-29 14:24:30.275 INF system: Loading settings from “/Users/paldybvik/Library/Containers/org.wfview.wfview/Data/Library/Preferences/org.wfview.wfview.plist”
2022-08-29 14:24:30.276 INF gui: Got Audio Output from Settings: “Bose QC35 II”
2022-08-29 14:24:30.276 INF gui: Got Audio Input from Settings: “Bose QC35 II”
2022-08-29 14:24:30.292 INF gui: Got Server Audio Input: “MacBook Air-mikrofon”
2022-08-29 14:24:30.292 INF gui: Got Server Audio Output: “MacBook Air-mikrofon”
2022-08-29 14:24:30.375 INF system: Cannot prepare WF view without rigCaps. Waiting on this.
2022-08-29 14:24:30.375 INF rig: creating instance of rigCommander()
2022-08-29 14:24:30.375 INF udp: Starting udpHandler user: “la7hm” rx latency: 86 tx latency: 269 rx sample rate: 48000 rx codec: 4 tx sample rate: 48000 tx codec: 4
2022-08-29 14:24:30.516 INF serial: Opened pt device: 26 , attempting to grant pt status
2022-08-29 14:24:30.516 INF serial: Opened pseudoterminal, slave name : /dev/ttys000
2022-08-29 14:24:30.518 INF serial: Created link to “/dev/ttys000” from “/Users/paldybvik/Library/Containers/org.wfview.wfview/Data/Downloads/rig-pty1”
2022-08-29 14:24:30.518 INF system: Received CommReady!!
2022-08-29 14:24:30.518 INF default: Setting rig state for wfmain
2022-08-29 14:24:30.518 INF udp: UDP Stream bound to local port: 63900 remote port: 60001
2022-08-29 14:24:31.088 INF udp: udpHandler : Received I am here from: QHostAddress(“::ffff:78.26.7.6”)
2022-08-29 14:24:31.154 INF udp: udpHandler : Received I am ready
2022-08-29 14:24:31.154 INF udp: udpHandler : Sending login packet
2022-08-29 14:24:31.227 INF udp: Got connection type: “WFVIEW”
2022-08-29 14:24:31.227 INF udp: udpHandler : Received matching token response to our request
2022-08-29 14:24:31.228 INF udp: udpHandler : Detected connection speed WFVIEW
2022-08-29 14:24:31.297 INF udp: udpHandler Received radio capabilities, Name: IC-7300 Audio: ICOM_VAUDIO CIV: “0x94” MAC: 0 : 144 : 199 : 68 : 53 : 58 CAPF 20481
2022-08-29 14:24:31.297 INF udp: Got Connection status for: IC-7300 Busy: 0 Computer IP “0.0.0.0”
2022-08-29 14:24:31.298 INF udp: Got Radio 0
2022-08-29 14:24:31.298 INF udp: Find available local ports
2022-08-29 14:24:31.299 INF default: Received serial port baud rate from remote server: 115200
2022-08-29 14:24:31.300 INF system: Delay command interval timing: 75 ms
2022-08-29 14:24:31.356 INF udp: Starting udpCivData
2022-08-29 14:24:31.357 INF udp: UDP Stream bound to local port: 61136 remote port: 60002
2022-08-29 14:24:31.357 INF udp: Starting udpAudio
2022-08-29 14:24:31.358 INF udp: UDP Stream bound to local port: 54979 remote port: 60003
2022-08-29 14:24:31.358 INF audio: Input audio handler starting: “Bose QC35 II”
2022-08-29 14:24:31.358 INF audio: Output audio handler starting: “Bose QC35 II”
2022-08-29 14:24:31.359 INF udp: udpHandler Got serial and audio request success, device name: “IC-7300”
2022-08-29 14:24:31.359 INF audio: Input No audio device was found. You probably need to install libqt5multimedia-plugins.
2022-08-29 14:24:31.359 INF audio: Output No audio device was found. You probably need to install libqt5multimedia-plugins.
2022-08-29 14:24:31.359 INF udp: Got Connection status for: IC-7300 Busy: 1 Computer Pals-Mac-wfview IP “91.186.77.128”
2022-08-29 14:24:31.413 INF udp: udpAudio : Received I am here
2022-08-29 14:24:31.413 INF udp: udpCivData : Received I am here
2022-08-29 14:24:31.529 INF rig: Using incomingCIVAddr: (int): 148 hex: “0x94”
2022-08-29 14:24:31.529 INF serial: Received rigCapabilities for “IC-7300”
2022-08-29 14:24:31.530 INF rig: Have rig ID: decimal: 148
2022-08-29 14:24:31.534 INF system: Delay command interval timing: 25 ms
2022-08-29 14:24:33.146 INF system: Warning: out of range RIT value received: 1478 Hz
2022-08-29 14:24:33.210 INF rig: Received 0x15 center span data: for frequency 25000
2022-08-29 14:24:33.452 INF udp: Audio Watchdog: no audio data received for 2s, restart required?
2022-08-29 14:27:06.568 INF udp: udpCivData 1 or more missing packets detected, previous: “0x39e1” current: “0x39e3”
2022-08-29 14:27:06.648 INF udp: udpCivData : sending request for missing packet : “0x39e2”
2022-08-29 14:27:06.748 INF udp: udpCivData : sending request for missing packet : “0x39e2”
2022-08-29 14:27:06.780 INF udp: udpCivData : Missing SEQ has been received! “0x39e2”
2022-08-29 14:28:02.456 INF udp: udpCivData 1 or more missing packets detected, previous: “0x4f22” current: “0x4f24”
2022-08-29 14:28:02.486 INF udp: udpCivData 1 or more missing packets detected, previous: “0x4f26” current: “0x4f29”
2022-08-29 14:28:02.546 INF udp: udpCivData : sending request for multiple missing packets : “23:4f:23:4f:27:4f:27:4f:28:4f:28:4f”
2022-08-29 14:28:02.647 INF udp: udpCivData : sending request for multiple missing packets : “23:4f:23:4f:27:4f:27:4f:28:4f:28:4f”
2022-08-29 14:28:02.663 INF udp: udpCivData : Missing SEQ has been received! “0x4f23”
2022-08-29 14:28:02.663 INF udp: udpCivData : Missing SEQ has been received! “0x4f27”
2022-08-29 14:28:02.747 INF udp: udpCivData : sending request for missing packet : “0x4f28”
2022-08-29 14:28:02.846 INF udp: udpCivData : sending request for missing packet : “0x4f28”
2022-08-29 14:28:02.938 INF udp: udpCivData : Missing SEQ has been received! “0x4f28”
2022-08-29 14:28:03.153 INF udp: udpCivData 1 or more missing packets detected, previous: “0x4f63” current: “0x4f65”
2022-08-29 14:28:03.200 INF udp: udpCivData 1 or more missing packets detected, previous: “0x4f68” current: “0x4f6c”
2022-08-29 14:28:03.247 INF udp: udpCivData : sending request for multiple missing packets : “64:4f:64:4f:69:4f:69:4f:6a:4f:6a:4f:6b:4f:6b:4f”
2022-08-29 14:28:03.346 INF udp: udpCivData : sending request for multiple missing packets : “64:4f:64:4f:69:4f:69:4f:6a:4f:6a:4f:6b:4f:6b:4f”
2022-08-29 14:28:03.391 INF udp: udpCivData : Missing SEQ has been received! “0x4f69”
2022-08-29 14:28:03.391 INF udp: udpCivData : Missing SEQ has been received! “0x4f6a”
2022-08-29 14:28:03.392 INF udp: udpCivData : Missing SEQ has been received! “0x4f6b”
2022-08-29 14:28:03.447 INF udp: udpCivData : sending request for missing packet : “0x4f64”
2022-08-29 14:28:03.547 INF udp: udpCivData : sending request for missing packet : “0x4f64”
2022-08-29 14:28:03.628 INF udp: udpCivData : Missing SEQ has been received! “0x4f64”
2022-08-29 14:29:31.912 INF rig: closing instance of rigCommander()
2022-08-29 14:29:31.913 INF udp: Closing UDP stream : “78.26.7.6” : 60003
2022-08-29 14:29:31.913 INF udp: Closing UDP stream : “78.26.7.6” : 60002
2022-08-29 14:29:31.913 INF udp: Sending token removal packet
2022-08-29 14:29:31.913 INF udp: Closing UDP stream : “78.26.7.6” : 60001
It can’t find your audio device. Press disconnect and try, even temporarily, another input and output device. If that doesn’t work, try one of the other audio subsystems (RT or PortAudio).
with senhaizer headset inn/out… Radiostatus no af. no mod. otherwise ok.
2022-08-29 19:47:18.334 INF system: “wfview version: 1.2e (Git:227ea8f on May 24 2022 at 16:19:23 by phil@Phils-MacBook-Pro-3.local)\nOperating System: macOS 12.5 (arm64)\nBuild Qt Version 5.15.2. Current Qt Version: 5.15.2\n”
2022-08-29 19:47:18.622 WRN qt.qpa.fonts: Populating font family aliases took 201 ms. Replace uses of missing font family “DejaVu Sans” with one that exists to avoid this cost.
2022-08-29 19:47:18.651 INF default: setState 1
2022-08-29 19:47:18.652 INF default: setState 0
2022-08-29 19:47:18.652 INF default: setState 1
2022-08-29 19:47:18.654 INF system: Loading settings from “/Users/paldybvik/Library/Containers/org.wfview.wfview/Data/Library/Preferences/org.wfview.wfview.plist”
2022-08-29 19:47:18.655 INF gui: Got Audio Output from Settings: “Bose QC35 II”
2022-08-29 19:47:18.655 INF gui: Got Audio Input from Settings: “Bose QC35 II”
2022-08-29 19:47:18.676 INF gui: Got Server Audio Input: “MacBook Air-mikrofon”
2022-08-29 19:47:18.676 INF gui: Got Server Audio Output: “MacBook Air-mikrofon”
2022-08-29 19:47:18.759 INF system: Cannot prepare WF view without rigCaps. Waiting on this.
2022-08-29 19:47:18.759 INF rig: creating instance of rigCommander()
2022-08-29 19:47:18.759 INF udp: Starting udpHandler user: “la7hm” rx latency: 86 tx latency: 269 rx sample rate: 48000 rx codec: 4 tx sample rate: 48000 tx codec: 4
2022-08-29 19:47:18.760 INF serial: Opened pt device: 28 , attempting to grant pt status
2022-08-29 19:47:18.760 INF serial: Opened pseudoterminal, slave name : /dev/ttys000
2022-08-29 19:47:18.761 INF serial: Created link to “/dev/ttys000” from “/Users/paldybvik/Library/Containers/org.wfview.wfview/Data/Downloads/rig-pty1”
2022-08-29 19:47:18.762 INF udp: UDP Stream bound to local port: 63432 remote port: 60001
2022-08-29 19:47:18.801 INF system: Received CommReady!!
2022-08-29 19:47:18.801 INF default: Setting rig state for wfmain
2022-08-29 19:47:19.344 INF udp: udpHandler : Received I am here from: QHostAddress(“::ffff:78.26.7.6”)
2022-08-29 19:47:19.398 INF udp: udpHandler : Received I am ready
2022-08-29 19:47:19.398 INF udp: udpHandler : Sending login packet
2022-08-29 19:47:19.451 INF udp: Got connection type: “WFVIEW”
2022-08-29 19:47:19.451 INF udp: udpHandler : Received matching token response to our request
2022-08-29 19:47:19.452 INF udp: udpHandler : Detected connection speed WFVIEW
2022-08-29 19:47:19.505 INF udp: udpHandler Received radio capabilities, Name: IC-7300 Audio: ICOM_VAUDIO CIV: “0x94” MAC: 0 : 144 : 199 : 68 : 53 : 58 CAPF 20481
2022-08-29 19:47:19.506 INF udp: Got Connection status for: IC-7300 Busy: 0 Computer IP “0.0.0.0”
2022-08-29 19:47:19.506 INF udp: Got Radio 0
2022-08-29 19:47:19.506 INF udp: Find available local ports
2022-08-29 19:47:19.508 INF default: Received serial port baud rate from remote server: 115200
2022-08-29 19:47:19.508 INF system: Delay command interval timing: 75 ms
2022-08-29 19:47:19.562 INF udp: Starting udpCivData
2022-08-29 19:47:19.563 INF udp: UDP Stream bound to local port: 53219 remote port: 60002
2022-08-29 19:47:19.563 INF udp: Starting udpAudio
2022-08-29 19:47:19.563 INF udp: UDP Stream bound to local port: 59728 remote port: 60003
2022-08-29 19:47:19.564 INF audio: Input audio handler starting: “Bose QC35 II”
2022-08-29 19:47:19.564 INF audio: Output audio handler starting: “Bose QC35 II”
2022-08-29 19:47:19.564 INF udp: udpHandler Got serial and audio request success, device name: “IC-7300”
2022-08-29 19:47:19.564 INF audio: Input No audio device was found. You probably need to install libqt5multimedia-plugins.
2022-08-29 19:47:19.564 INF audio: Output No audio device was found. You probably need to install libqt5multimedia-plugins.
2022-08-29 19:47:19.564 INF udp: Got Connection status for: IC-7300 Busy: 1 Computer Pals-Mac-wfview IP “91.186.77.128”
2022-08-29 19:47:19.618 INF udp: udpAudio : Received I am here
2022-08-29 19:47:19.619 INF udp: udpCivData : Received I am here
2022-08-29 19:47:19.644 INF rig: Using incomingCIVAddr: (int): 148 hex: “0x94”
2022-08-29 19:47:19.644 INF serial: Received rigCapabilities for “IC-7300”
2022-08-29 19:47:19.644 INF rig: Have rig ID: decimal: 148
2022-08-29 19:47:19.647 INF system: Delay command interval timing: 25 ms
2022-08-29 19:47:21.159 INF system: Warning: out of range RIT value received: 1478 Hz
2022-08-29 19:47:21.369 INF rig: Received 0x15 center span data: for frequency 25000
2022-08-29 19:47:21.939 INF udp: Audio Watchdog: no audio data received for 2s, restart required?
Hi, wfview seems to still be looking for “Bose QC35 II“. If your are using Sennheiser then you need to select that in the settings and press “save settings”. Then relaunch.
You might also want to try some of the other audio subsystems such as RT audio or QT audio.
I still get no sound, but I have made this changes: On the server side I have changed to Mac OS (M1 prosessor). Running wfview 12e.
On the client side I run MAC os (M1 processor) macOS Monterey 12.5 and wfview 12e. default audiotype. I get connected the waterfall is working - I can turn the station on/off - but no sound. The rx latency turns red 33986 ms. the other parameters seems ok. Using control port 60001, CivPort 60002 and Audio 60003.If I changes the audio system to port audio the system stopps.
