- Operating System: WIN11
- Radio Model: icom 7610
- Method of radio connectivity Ethernet
the cluster is running but no spots viwe in spectrum sri
what can i do?
what can i do?
Do you see the spots in the cluster log?
yes many spots are in cluster but not in spectrum view
Which DX cluster are you using as it has only been tested with DXSpider, I suspect the format of other clusters may be slightly different?
Hello, i have
telnet.reversebeacon.net
rbn.telegraphy.de
Ah, That is the problem, connecting directly to RBN servers is not supported, you need to connect to a cluster node.
ok yes now i have it hi
73 tnx Peter
