No transmit/intermittent transmit
IC7300
Using linux mint 22.1
Wfview v 2.04 for linux.
IC7300
I had very little trouble with 1.64 and the transmit or receive audio. Can’t say that for the new version.
I can get the remote client to receive on laptops with Mint and Windows 11. Neither will send audio. Sometimes I have it but 90 percent usually nothing.
I am using a Phillips wired usb headset that works on both fine with other applications. I can see sound on the meters in the client when switched to transmit. The Burr Brown codec is setup on the server. Running QT audio on both sides. I have tried PWAudio control and can see everything on the linux laptop. Windows shows the same.
I re installed everything again but no joy.
Maybe I may have to back down to 1.64.
De N0QJA
Hi John,
If you’re seeing the sound in the meters during transmit you are very close!
Can you verify that the transmit audio modulation source on the radio is set to “USB” please? You can do this within wfview under Settings → Radio Settings.
