Hi, am using a server client setup with a 7300 with server on a Pi and client on a windows laptop, with wfview 1.62 on both. I use the BurrBrown devices on the server, and an USB headset on the client. Recieve audio is working, but not transmit. The TX audio meter on the client does move, though. But not the ALC meter.
I have rebooted the Icom and the server and client computers and instances of wfview, and also shifted the audio devices, saved and reconnected. But same result, RX sound is OK, but no TX.
I wonder if the missing TX is caused by the client laptop. There is another problem on this, the selected RX device (internal speaker or USB headset phones) sometimes has to be changed back and forth to work. And the TX audio did occasionally work a few days ago.
The Windows client laptop is only used as a temporary client for troubleshooting at my remote site, At my home QTH I use a Pi as client.
You won’t see any mod input indication from the server. Assuming you DO have USB selected as the mod input source for the current mode, the most likely cause of this is that the wrong device is selected in the server setup, this must be the USB codec devices provided by the radio. Also worth checking it isn’t muted externally to wfview.
