OFF topic! Yaesu FT710 (and others)
Hello again…
Until recently my radios were an Icom IC7300 and a Xiegu G90, The Icom I ever use via WFView.
Now I’m also the happy owner of a Yaesu FT-710, and I connect it directly to the QLog software. Until now I was using CQRLOG via IP from WLView into my Icom radio, and it was going great.
But the Yaesu , I find it a bit more comfortable to receive than the others. Less noisy And so now it’s mainstream radio. Sorry!
Actually, that’s not why I’m writing.
The radio (yaesu) has a remote control system with an added hardware, SCU-LAN10 that allows remote control, and also lets you see the waterfall (ugly yaesu waterfall).
It uses ports for audio and control, similar to ICOM, but without the additional hardware we have no access.
This software from Yaesu only exists for windows, and not for Linux. It may work via wine, or it may not.
But I have seen something, which I think can be interesting, is that apart from 2 serial ports that generate the USB bus, if it is activated in the menu “operating setting” and GENERAL, SCU-LAN10 in ON, it activates a other device on the usb bus: a GPIO SPI/I2C bus, I don’t know if this can be interesting to control the radio. Attached is a syslog capture.
Maybe you could connect to this bus and “see” the yaesu from WFview?
Cheers!
If you can figure out how to get the waterfall out over serial (or SPI/I2C), then you would have a candidate for inclusion as we begin to write code for more radios.
I looked around the internet and nobody seems to know much about how to do it.
I just spoke to a colleague who has an FTDX10 and does not have the option to activate the SCU-LAN10 in the menu of his radio.
I’ve been looking at the connection manuals for the 3 yaesu radios that connect to the remote control hardware, and the FT710 is the only one that does it all with just the USB cable. The others use the ACC port.
Without knowing anything about how this device works, I think the FT710 is the only one of the three that includes an I2C bus.
When I have time and can go to the colleague’s house, I will try to find out if there is an I2C bus in the list of devices that appear when connecting the USB of a Yaesu FTDX10 or FTDX101, but I suspect that it will not be there.
I haven’t found any information on the internet about this either. But the truth is that every day more and more FT710 are sold. It would be good to find an economical way to be able to use the equipment remotely. Too bad I don’t have any programming knowledge, even so I’ll see if I can access the I2C bus or the gpio… I found some libraries but I don’t even know where to start.
I would guess the I2C and SPI stuff is for ancillary functions that they forgot to or couldn’t assign to commands over serial. House keeping things like power/standby/sleep functions and that sort of stuff.
The second serial port that appears is likely dedicated to the waterfall data. I’m just guessing here, but it’s a lot of data compared to the commands, and I could see them wanting it on a separate interface.
What you could try is enabling the SCU and connecting the SCU, and then making a connection to it. Then unplug the SCU and swap in a linux PC. Open that secondary serial port and see if any data are coming out. Dump any data to a file, and then share :slight_smile: Or maybe the thing detects the SCU unplug and stops streaming the data, who knows. Maybe it’ll stream data the moment you enable the SCU in the menu, it might.
Happy hunting,
Well, continuing with the offtopic, I have reviewed the manuals of the two Yaesu hybrids and in both cases, in addition to the USB cable, they connect the ACC port.
also, and as my friend confirmed to me, the FTDX10, and I presume the same is the case with the FTDX101, They have no option to activate or deactivate the SCU-LAN10 in their menus.
So, I understand that the function of the FT4222 port that is activated by switching SCU-LAN10 ON is to generate the equivalent data to the ACC port of the other two Yaesu SDR models.
So it would be logical to find the information that is in the ACC.
On the second serial port, the baud rate can be chosen in the menu, just like with port number 1.
By the way, there is a third serial port… although it doesn’t appear on the USB bus.
The FTDX10 has it with a standard 9 pin port, and I wonder if this third port is simply not connected anywhere and is only on the board, inside.
It always seemed to me that yaesu makes each device with a different group of engineers, and they don’t talk to each other. I’ve had an FTM100 and at the same time an FT70D, which are devices from the same era, with digital modulation. And I remember that the way to access the same digital services via RF was totally different in the two devices, and no menu looked alike. By this I mean that yaesu is a bit chaotic, and yes, this time, in my opinion, he got it right with the FT710 receiver, but I think he went on doing it, not knowing very well what he was doing or what hardware he would end up needing. And here may be the explanation of the third serial port that does not appear anywhere but in the menu.
Here my list of usb, first is Icom 7300
Here you have the Yaesu 710 menu
another thing I’ve seen is that the serial ports don’t die when turning off the radio, the sound cards stop, and also the I2C/SPI. This means that the radio can be started via the serial port, which if it remains activated.
FLRIG manages to open or close the radio, via serial port, which confirms it, even if you choose FTDX10 instead of FT710, and we know that FTDX10 only has serial ports.
About the second USB port, I configured it in the QLOG and it seems to work exactly the same as the other one. As much as it also makes the same mistakes, both in the mode and in the frequency modification. Maybe they generate them to be able to have 2 programs at the same time connected to the radio, one on each port. I doubt very much that the waterfall data goes through there.
Today stop the search…
Very interesting! Two cat interfaces. A handy feature really.
I know the usual commands are pretty well-known.
If anyone knows how the waterfall happen, I’m all ears. Maybe there’s raw I/Q and the computer does the FFT?
My best guess is that you have to buy that $300 box because they were not able to complete the design with those features built-in. Schedule, cost, and engineering constraints likely lead to them making the box an external addition.
We do plan to eventually support other brands of radios, pending the discovery or publishing of their protocols.
Hello Eliot, Jordi,
Thanks for letting me in to this discussion. I got some recent experience with FTDI chips and drivers, so i gave it a try and wrote a little c# program based on my Q&A sessions above. Here i share my findings so far:
@eb3am The radio hase 3 CAT interfaces, the 3rth is de real one at the acc port.
So far the guesses in my Q&A session seems to add up, summary:
  • The chip works in de mode zero, with one SPI and one other interface. (That is not used.)
  • They are marked as A and B, according the docs the SPI interface is at A.
  • I did a READ on the A interface with the default credentials and received a stream of bytes.
  • Wrote the bytes to a file.
Next: Read bytes with different credentials (clock speed, msb/lsb, databit length, buffer length).
Investigate the results and share the files here.
Imre
de PD2I
Morning,
My research had ‘some’ results:
using Iot.Device.Ft4222; // nuget package
using Iot.Device.FtCommon; // nuget package
configuration:
Select the device with description “FT4222 A”
ClockFrequency = 125_000,
// The SPI mode being used.
Mode = SpiMode.Mode0,
// The bus ID the device is connected to.
BusId = 0,
// The chip select line used on the bus. -1 if not used
ChipSelectLine = 1,
// The length of the data to be transfered
DataBitLength = 8, // 1 byte
// Specifies order in which bits are transferred first on the SPI bus.
DataFlow = DataFlow.MsbFirst, LsbFirst, MsbFirst
// Specifies which value on chip select pin means “active”.
ChipSelectLineActiveState = PinValue.Low
  1. Every 4096 bytes the data seems to repeat, so we read buffers with that size.
  2. When changing clockspeed and/or the amount of buffers read, the format of the content is the same.
  3. Tried with a dummy load and then at a buzzy band, the First 850 bytes (0000-1349) changes sigificant. Low values for high levels and vica versa.
  4. At 06A4 a new Block of data starts, ending at 18FB (Gues: bandwith waterfall)
  5. At 1B65 a small piece of data, that is the same in all frames (config?)
  6. Every buffer ends with 16 times FF
WARNING: Do not send bytes thru the interface! In the examples programm 2 byte were send, it screwed up my rig. Luckely a reset repared it.
I have no idea if its i/q data, visual data or else.
Download: C# programm;
in ‘\bin\Debug\net6.0-windows\Samples’ many recordings
https://www.livep2000.nl/ft710interface.zip
I hope someone can make something out of it.
Imre
I’ve been playing with this the past few days. Have identified the waterfall data, AF FFT data, AF Oscilloscope data, and am working on figuring out the radio parameter data.
Here’s a github repo with my findings so far, and a test script in python working with the FT710, plotting the waterfall data, oscope data, and AF fft data.
I welcome any and all additional findings
This is great!
How often do you get spectrum data?
Each 4KB data packet takes approximately 12ms, at least using python.
That’s an impressive 83 FPS of pretty wide spectrum data.
It would be really cool to build a SCU-LAN10 with a more open interface, which is something I think you could do with a Pi or even a microcontroller. Heck, you could even translate the data to Icom-speak.
It’ll be interesting to see where this goes.
I am really very impressed.
The truth is that I would really like to be able to see the watefall of the yaesu in WFview.
After reading all these good news, I think it is not impossible.
Then it would be worth adding the yaesu to the project.
Thank you all for the work you are doing.
The question is now, is it best to try and support the SCU-LAN10 ($$$ plus an unknown protocol), or, is it best to recommend a Raspberry Pi with a SPI cable and USB audio to the radio?
It annoys me greatly that the LAN option was not built-in, because it really lowers the number of people that use it. And the price of that option is rather crazy – over $300 right now. It kind of makes me think we should DIY it with a Pi. It would certainly make the protocol easier – we could just duplicate the protocol we are already using.
It would be a fun one, especially with the audio scope+fft coming over the SPI already.
It is definitely best to have free source software that allows you to connect the radios to the network.
If it has to work on a Rpi, or a PC, it doesn’t matter.
If, as Ratmandu says, the SPI data also exists in the FTDX*** the software would have many users, as there are many more radios that can connect to it.
For the FT-710, you don’t need any extra hardware, just a USB cable on the same port that brings in the CAT serial port, and the audio device.
For the FTDX10, I’m currently working on getting data from it, but it should be easy enough to build a small, inexpensive box that does usb->spi the same way that the FT-710 does.
It also annoys me that they didn’t put LAN on board, especially since the microcontroller they are using on the display board (which is where all of the communication lies, re: cat and waterfall), has an ethernet interface. It would have cost ~$0.30-0.60 per unit to add the port to the radio itself.
does that (over usb) cause speed issues?
Not that I’ve been able to notice.
This is how yaesu does it officially with the SCU-LAN10, so it shouldn’t cause any issues.
I’m very excited and happy to see everyone actively discussing the data protocols for connecting the FT-710 or FTDX10 to a computer. I’m curious about the progress of these projects and whether it might be possible in the future to develop software based on WFVIEW to control Yaesu radios. Have there been any recent updates or advancements in this research?
