Hello, is there any way to read on Wfview infomration about temperature and voltage displayed on the IC7610?
in addition, more importantly, is ti possible to check for overlow so to adjust the RF if necessary?
73
Peter IU0DHV
73
Peter IU0DHV
Voltage is available as an additional meter (click below the main meter to add it).
Should an Overflow occur, OVF will be displayed on the top of the scope.
Unfortunately, Icom radio’s don’t report temperature.
Thank you for the quick reply and the info. Now I have seen the voltage meter. And the OVF indication on top of the scope. Very useful!
As for the temperature the IC-7610 does show the temperature. When you say “don’t report it” do you mean it is not possibile to read it or something similar?
73
Yes there is no command to retrieve the temperature value.
ok clear thanks. That’s a pity as it is may be an important info. The good news is that the temperature never increased during my short experience with this radio, even dury heavy duty transmission.
