So i managed to get it to install on PopOS 22.04 (annoying in itself) but when I run I get this error
ticnitsi@pop-os:~/Downloads/dist$ wfview
setState 1
setState 1
setState 1
setState 1
setState 1
setState 1
setState 1
setState 1
setState 1
setState 1
setState 1
setState 1
setState 1
setState 1
setState 1
setState 1
setState 1
setState 1
setState 1
Segmentation fault (core dumped)
But I see no logfiles generated or anything that can tell me more of the error
I am trying to build a package for Fedora and hitting the same building from source. The build appears to finish successfully, but on running it just core dumps.
segfaulting with the prebuilt binary can be due to a too new OS, or a too old OS.
now. POP-OS 22.04 seems new so maybe you should build t yourself.
In any case the issues arise when you have too different QT versions; Fedora is known to be old when it comes to libraries (depending on the version you try too).
I won’t spread my personal feelings for things that (even remotely) is touched by RH.
use the script to compile
I think pop OS use a debian packages
Debian Build Script:
For debian-based systems (Ubuntu, Mint, Debian, Raspberry Pi, etc), you may obtain the latest version of the master branch of wfview by running this build script:
