K7MVE
(Matt)
28 December 2021 06:48
#1
I am wanting to use WFView to remotely operate my Icom IC-7300 at my parent’s house. I have installed it on the Pi 4. Everything is working while on the Pi locally (can see the waterfall, tune around, etc.) but when I enable server operation WFView does not seem to be actually opening ports 50001-50003 on any interface when I run “netstat -tulpn | grep LISTEN”. I have saved, closed, reopened, rebooted, etc. I am not at my parents right now and I do not have anything else besides the Pi that I can test from but the fact that the ports are not open seems pretty cut and dry as far as if server operation is working. The only thing I can think of is that I am running on a HamPi image and there is something else on the image that is preventing the ports from opening? Am I on the right track?
73,
Matt K7MVE
roeland
(Roeland Jansen)
28 December 2021 06:58
#2
Matt,
you can omit the -t option in netstat; you only need to see udp.
That also means that you cannot grep on “LISTEN” as there usually
is no state when using udp.
you should be able to grep on the ports you defined in the config.
to see if the ports are exposed externally, there are a few ways to test.
Assuming you have UDP 50001/2/3 open on the firewall, not using a VPN and such,
you eventually could check the external address with nmap.
sudo nmap -sU <target_ip | hostname> -p 50001-50003
Starting Nmap 7.70 ( https://nmap.org ) at 2021-12-28 07:56 CET
Nmap scan report for targethostname (target_ip))
Host is up (0.0026s latency).
Other addresses for hostname (not scanned): [ipv6_addr]
rDNS record for target_ip: hostname
PORT STATE SERVICE
50001/udp open|filtered unknown
50002/udp open|filtered unknown
50003/udp open|filtered unknown
Nmap done: 1 IP address (1 host up) scanned in 1.68 seconds
K7MVE
(Matt)
28 December 2021 07:27
#3
K7MVE:
netstat -tulpn
Hi Roeland!
Thanks for getting back to me. I have run a sudo netstat | grep 50001 and did not get and results. Running a sudo netstat with no switches gives me:
pi@hampi:~ $ sudo netstat
Active Internet connections (w/o servers)
Proto Recv-Q Send-Q Local Address Foreign Address State
tcp 0 0 192.168.163.20:40032 165.254.239.130:https ESTABLISHED
tcp 0 0 192.168.163.20:54232 212.119.29.132:https ESTABLISHED
tcp 0 0 localhost:36100 localhost:36581 ESTABLISHED
tcp 0 0 localhost:36581 localhost:36100 ESTABLISHED
Active UNIX domain sockets (w/o servers)
Proto RefCnt Flags Type State I-Node Path
unix 2 [ ] DGRAM 14089 /tmp/.vncserver-license/0.799
unix 2 [ ] DGRAM 14842 /run/user/1000/systemd/notify
unix 4 [ ] DGRAM 9692 /run/systemd/notify
unix 2 [ ] DGRAM 9706 /run/systemd/journal/syslog
unix 22 [ ] DGRAM 9713 /run/systemd/journal/dev-log
unix 6 [ ] DGRAM 9715 /run/systemd/journal/socket
unix 4 [ ] DGRAM 13905 /var/run/wpa_supplicant/wlan0
unix 2 [ ] DGRAM 13913 /var/run/wpa_supplicant/p2p-dev-wlan0
unix 2 [ ] DGRAM 18161 /tmp/dhcpcd-pi/libdhcpcd-wpa-1243.0
unix 2 [ ] DGRAM 18162 /tmp/dhcpcd-pi/libdhcpcd-wpa-1243.1
unix 3 [ ] STREAM CONNECTED 17697
unix 3 [ ] STREAM CONNECTED 15063 /run/user/1000/bus
unix 3 [ ] STREAM CONNECTED 11186 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 17106
unix 3 [ ] DGRAM 14844
unix 3 [ ] STREAM CONNECTED 18191 /run/user/1000/speech-dispatcher/speechd.sock
unix 3 [ ] STREAM CONNECTED 41269
unix 3 [ ] STREAM CONNECTED 17598
unix 3 [ ] STREAM CONNECTED 15984 /run/systemd/journal/stdout
unix 2 [ ] DGRAM 9800
unix 3 [ ] STREAM CONNECTED 19534
unix 3 [ ] STREAM CONNECTED 17099 /run/systemd/journal/stdout
unix 2 [ ] DGRAM 14809
unix 3 [ ] STREAM CONNECTED 14462 /run/systemd/journal/stdout
unix 2 [ ] DGRAM 11088
unix 3 [ ] STREAM CONNECTED 41273
unix 3 [ ] STREAM CONNECTED 19594
unix 3 [ ] STREAM CONNECTED 17596
unix 3 [ ] STREAM CONNECTED 19537
unix 3 [ ] STREAM CONNECTED 9863
unix 3 [ ] STREAM CONNECTED 17609 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 17659
unix 2 [ ] DGRAM 9873
unix 3 [ ] DGRAM 9693
unix 3 [ ] STREAM CONNECTED 19536
unix 3 [ ] STREAM CONNECTED 14442
unix 3 [ ] STREAM CONNECTED 10484 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 16231 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 14800
unix 3 [ ] DGRAM 9876
unix 3 [ ] DGRAM 9694
unix 3 [ ] STREAM CONNECTED 19522 /run/user/1000/pulse/native
unix 3 [ ] STREAM CONNECTED 17658
unix 3 [ ] STREAM CONNECTED 13868
unix 3 [ ] STREAM CONNECTED 19521
unix 3 [ ] STREAM CONNECTED 14934 /run/user/1000/bus
unix 3 [ ] DGRAM 9877
unix 3 [ ] STREAM CONNECTED 17606
unix 3 [ ] STREAM CONNECTED 19535
unix 3 [ ] STREAM CONNECTED 17607 /run/user/1000/bus
unix 3 [ ] STREAM CONNECTED 20164
unix 3 [ ] STREAM CONNECTED 16382 /run/user/1000/bus
unix 3 [ ] STREAM CONNECTED 39227 @/tmp/dbus-NlBqLqeFuo
unix 2 [ ] DGRAM 14779
unix 3 [ ] STREAM CONNECTED 20165 /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 16381
unix 3 [ ] STREAM CONNECTED 16262 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 11091
unix 3 [ ] STREAM CONNECTED 12764 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 39224 @/tmp/.X11-unix/X0
unix 2 [ ] DGRAM 14817
unix 2 [ ] DGRAM 12880
unix 3 [ ] STREAM CONNECTED 17116 /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 17662
unix 3 [ ] DGRAM 14843
unix 3 [ ] STREAM CONNECTED 18509 /run/user/1000/bus
unix 3 [ ] STREAM CONNECTED 14847
unix 3 [ ] STREAM CONNECTED 20167 /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 16371
unix 3 [ ] STREAM CONNECTED 17660 /run/user/1000/bus
unix 3 [ ] STREAM CONNECTED 16868 /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 13039 /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 18014
unix 3 [ ] STREAM CONNECTED 21601
unix 3 [ ] STREAM CONNECTED 45074
unix 3 [ ] STREAM CONNECTED 19503
unix 3 [ ] STREAM CONNECTED 18021
unix 3 [ ] STREAM CONNECTED 8122
unix 3 [ ] STREAM CONNECTED 18498 /run/user/1000/bus
unix 3 [ ] STREAM CONNECTED 16930
unix 3 [ ] STREAM CONNECTED 45075
unix 3 [ ] STREAM CONNECTED 39228 /run/user/1000/bus
unix 3 [ ] STREAM CONNECTED 12761
unix 3 [ ] STREAM CONNECTED 18558 /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 14933 /run/user/1000/bus
unix 2 [ ] DGRAM 12906
unix 3 [ ] STREAM CONNECTED 18507 @/tmp/dbus-NlBqLqeFuo
unix 3 [ ] STREAM CONNECTED 39223
unix 3 [ ] STREAM CONNECTED 18020
unix 3 [ ] STREAM CONNECTED 18704
unix 3 [ ] STREAM CONNECTED 18490 @/tmp/dbus-NlBqLqeFuo
unix 3 [ ] STREAM CONNECTED 17969 /run/user/1000/bus
unix 3 [ ] STREAM CONNECTED 17962 /run/user/1000/bus
unix 3 [ ] STREAM CONNECTED 16040
unix 3 [ ] STREAM CONNECTED 17961
unix 3 [ ] STREAM CONNECTED 16338
unix 3 [ ] DGRAM 14888
unix 3 [ ] STREAM CONNECTED 16341
unix 3 [ ] STREAM CONNECTED 16353
unix 3 [ ] DGRAM 14887
unix 3 [ ] STREAM CONNECTED 16042 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 18445 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 13906 /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 17949
unix 3 [ ] STREAM CONNECTED 18988
unix 2 [ ] DGRAM 16441
unix 2 [ ] DGRAM 12966
unix 3 [ ] STREAM CONNECTED 18705 /run/user/1000/at-spi2-5C4TE1/socket
unix 3 [ ] STREAM CONNECTED 17226 /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 16929
unix 3 [ ] STREAM CONNECTED 13037 /run/dbus/system_bus_socket
unix 2 [ ] DGRAM 13190
unix 3 [ ] STREAM CONNECTED 13127
unix 3 [ ] STREAM CONNECTED 18002 /run/user/1000/bus
unix 3 [ ] STREAM CONNECTED 18549
unix 3 [ ] STREAM CONNECTED 17213
unix 3 [ ] STREAM CONNECTED 15594
unix 3 [ ] STREAM CONNECTED 15595
unix 3 [ ] STREAM CONNECTED 19488 /run/user/1000/bus
unix 3 [ ] STREAM CONNECTED 17937 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 13029
unix 3 [ ] STREAM CONNECTED 18001
unix 3 [ ] STREAM CONNECTED 18000
unix 3 [ ] STREAM CONNECTED 14598 /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 18450 @/tmp/dbus-NlBqLqeFuo
unix 3 [ ] STREAM CONNECTED 14620 /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 15546
unix 3 [ ] STREAM CONNECTED 12936
unix 3 [ ] STREAM CONNECTED 45642
unix 3 [ ] STREAM CONNECTED 18711
unix 3 [ ] STREAM CONNECTED 18008
unix 3 [ ] STREAM CONNECTED 18007
unix 3 [ ] STREAM CONNECTED 18451 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 14613 /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 18713
unix 3 [ ] STREAM CONNECTED 16337
unix 3 [ ] STREAM CONNECTED 15551
unix 3 [ ] STREAM CONNECTED 17920 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 17919
unix 3 [ ] STREAM CONNECTED 18195 /run/user/1000/at-spi2-PIFPE1/socket
unix 3 [ ] STREAM CONNECTED 18631 /run/user/1000/menu-cached-:0
unix 3 [ ] STREAM CONNECTED 13024
unix 2 [ ] DGRAM 16064
unix 3 [ ] STREAM CONNECTED 13040 /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 16461
unix 3 [ ] STREAM CONNECTED 45643 /run/user/1000/bus
unix 3 [ ] STREAM CONNECTED 21600 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 17342
unix 3 [ ] STREAM CONNECTED 15439
unix 3 [ ] STREAM CONNECTED 13031 /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 17220 /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 17922
unix 3 [ ] STREAM CONNECTED 13416
unix 3 [ ] STREAM CONNECTED 17939
unix 3 [ ] STREAM CONNECTED 16437
unix 3 [ ] STREAM CONNECTED 13409
unix 3 [ ] STREAM CONNECTED 15592
unix 3 [ ] STREAM CONNECTED 13408
unix 3 [ ] STREAM CONNECTED 16420
unix 3 [ ] STREAM CONNECTED 17938
unix 3 [ ] STREAM CONNECTED 20555 /run/user/1000/pulse/native
unix 3 [ ] STREAM CONNECTED 17225
unix 3 [ ] STREAM CONNECTED 16680 /run/dbus/system_bus_socket
unix 2 [ ] DGRAM 13406
unix 3 [ ] STREAM CONNECTED 14623 /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 13028
unix 3 [ ] STREAM CONNECTED 17925 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 16462 /run/dbus/system_bus_socket
unix 2 [ ] DGRAM 50178
unix 3 [ ] STREAM CONNECTED 17228
unix 2 [ ] DGRAM 14996
unix 3 [ ] STREAM CONNECTED 14939 /run/user/1000/bus
unix 3 [ ] STREAM CONNECTED 45644
unix 3 [ ] STREAM CONNECTED 48272
unix 3 [ ] STREAM CONNECTED 17935 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 48357
unix 3 [ ] STREAM CONNECTED 14268 /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 46673 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 17423 /run/user/1000/pipewire-0
unix 2 [ ] DGRAM 39925
unix 3 [ ] STREAM CONNECTED 17494 /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 14997
unix 3 [ ] STREAM CONNECTED 40513 /run/cups/cups.sock
unix 3 [ ] STREAM CONNECTED 14947
unix 3 [ ] STREAM CONNECTED 18521
unix 3 [ ] STREAM CONNECTED 40497
unix 3 [ ] STREAM CONNECTED 19460 /run/user/1000/bus
unix 3 [ ] STREAM CONNECTED 16809 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 45686 /run/user/1000/pulse/native
unix 3 [ ] STREAM CONNECTED 18519
unix 3 [ ] STREAM CONNECTED 17422 /run/user/1000/pipewire-0
unix 3 [ ] STREAM CONNECTED 14949
unix 3 [ ] STREAM CONNECTED 18520 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 14950
unix 3 [ ] STREAM CONNECTED 14235
unix 3 [ ] STREAM CONNECTED 47343 @/tmp/dbus-NlBqLqeFuo
unix 3 [ ] STREAM CONNECTED 14267
unix 3 [ ] STREAM CONNECTED 14918 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 14917
unix 3 [ ] STREAM CONNECTED 40512
unix 3 [ ] STREAM CONNECTED 18499 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 40496
unix 3 [ ] STREAM CONNECTED 14948 /run/user/1000/bus
unix 3 [ ] STREAM CONNECTED 14931
unix 3 [ ] STREAM CONNECTED 14930
unix 3 [ ] STREAM CONNECTED 16305
unix 3 [ ] STREAM CONNECTED 11233 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 41280 /run/user/1000/at-spi2-0B1PE1/socket
unix 3 [ ] STREAM CONNECTED 16432 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 18486 /run/user/1000/bus
unix 3 [ ] STREAM CONNECTED 17223 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 16333
unix 2 [ ] DGRAM 17068
unix 2 [ ] DGRAM 15062
unix 3 [ ] STREAM CONNECTED 17071
unix 3 [ ] STREAM CONNECTED 14012
unix 3 [ ] STREAM CONNECTED 20488
unix 3 [ ] STREAM CONNECTED 14617
unix 3 [ ] STREAM CONNECTED 18683 /run/dhcpcd.unpriv.sock
unix 3 [ ] STREAM CONNECTED 18453 @/tmp/dbus-NlBqLqeFuo
unix 3 [ ] STREAM CONNECTED 15061 /run/user/1000/bus
unix 3 [ ] STREAM CONNECTED 14120
unix 3 [ ] STREAM CONNECTED 18452
unix 3 [ ] STREAM CONNECTED 16202
unix 3 [ ] STREAM CONNECTED 14147
unix 3 [ ] STREAM CONNECTED 11145 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 8051
unix 3 [ ] STREAM CONNECTED 18513 /run/systemd/journal/stdout
unix 2 [ ] DGRAM 14438
unix 3 [ ] STREAM CONNECTED 10973
unix 3 [ ] STREAM CONNECTED 13801
unix 3 [ ] STREAM CONNECTED 12823 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 18682 /run/dhcpcd.unpriv.sock
unix 3 [ ] STREAM CONNECTED 17594 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 16806 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 42182
unix 3 [ ] STREAM CONNECTED 17198
unix 3 [ ] STREAM CONNECTED 11073
unix 3 [ ] STREAM CONNECTED 14119
unix 3 [ ] STREAM CONNECTED 18158
unix 3 [ ] STREAM CONNECTED 18134 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 18013
unix 3 [ ] STREAM CONNECTED 14891 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 12749 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 18485
unix 3 [ ] STREAM CONNECTED 17931 /run/user/1000/bus
unix 3 [ ] STREAM CONNECTED 18157
unix 3 [ ] STREAM CONNECTED 17924 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 17061
unix 2 [ ] DGRAM 16871
unix 3 [ ] STREAM CONNECTED 18441
unix 3 [ ] STREAM CONNECTED 16272 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 16043 /run/systemd/journal/stdout
unix 2 [ ] DGRAM 10979
unix 2 [ ] DGRAM 17414
unix 3 [ ] STREAM CONNECTED 13946
unix 3 [ ] STREAM CONNECTED 10972
unix 2 [ ] DGRAM 16822
unix 3 [ ] STREAM CONNECTED 11185 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 18025
unix 3 [ ] STREAM CONNECTED 12822 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 16271
unix 3 [ ] STREAM CONNECTED 14110
unix 3 [ ] STREAM CONNECTED 17234 /run/user/1000/bus
unix 3 [ ] STREAM CONNECTED 15142
unix 3 [ ] STREAM CONNECTED 17170 /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 11168 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 17232
unix 3 [ ] STREAM CONNECTED 8127
unix 3 [ ] STREAM CONNECTED 18024
unix 3 [ ] STREAM CONNECTED 12817 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 14647 /run/dbus/system_bus_socket
unix 2 [ ] DGRAM 15125
unix 3 [ ] STREAM CONNECTED 14550 /run/systemd/journal/stdout
unix 2 [ ] DGRAM 11083
unix 2 [ ] DGRAM 10408
unix 3 [ ] STREAM CONNECTED 18510 /run/user/1000/bus
unix 2 [ ] DGRAM 11258
unix 3 [ ] STREAM CONNECTED 12824 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 17418
unix 3 [ ] STREAM CONNECTED 18155 /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 18022
unix 2 [ ] STREAM CONNECTED 14107
unix 3 [ ] STREAM CONNECTED 13038 /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 19490 @/dbus-vfs-daemon/socket-qL50qktC
unix 3 [ ] STREAM CONNECTED 18508 @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 15440 /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 8129
unix 3 [ ] STREAM CONNECTED 16332
unix 3 [ ] STREAM CONNECTED 18438
unix 2 [ ] DGRAM 17070
unix 2 [ ] STREAM CONNECTED 14095
unix 3 [ ] STREAM CONNECTED 17242
unix 3 [ ] STREAM CONNECTED 20499
unix 3 [ ] STREAM CONNECTED 16304
unix 3 [ ] STREAM CONNECTED 14625
unix 3 [ ] STREAM CONNECTED 11184
unix 2 [ ] DGRAM 20492
unix 3 [ ] STREAM CONNECTED 18439
unix 3 [ ] STREAM CONNECTED 15018 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 16872
unix 3 [ ] STREAM CONNECTED 12750 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 16203
unix 3 [ ] STREAM CONNECTED 17554 /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 14310
unix 3 [ ] STREAM CONNECTED 20501
unix 3 [ ] STREAM CONNECTED 14626 /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 13150 /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 17918 /run/user/1000/bus
unix 3 [ ] STREAM CONNECTED 14430
unix 3 [ ] STREAM CONNECTED 11005
unix 3 [ ] STREAM CONNECTED 18518 /run/systemd/journal/stdout
unix 2 [ ] DGRAM 14399
unix 3 [ ] STREAM CONNECTED 19549 /run/user/1000/pulse/native
unix 3 [ ] STREAM CONNECTED 13030 /run/dbus/system_bus_socket
unix 2 [ ] STREAM CONNECTED 14102
unix 3 [ ] STREAM CONNECTED 13883
roeland
(Roeland Jansen)
28 December 2021 07:33
#4
in the server setup you did enable the server setup?
(Including user/pass etc)
roeland
(Roeland Jansen)
28 December 2021 07:35
#5
something like this (your image may show different; here it’s set to UDP 50011/12/13)
K7MVE
(Matt)
28 December 2021 09:56
#6
I have attached what my server setup screen looks like. I also tried different ports in this screen just in case there what a conflict but the results were the same. I have saved, exited wfview, reopened, checked ports, exited wfview, rebooted pi, opened wfview, checked ports.
K7MVE
(Matt)
28 December 2021 09:59
#7
Attached is my view tab. Everything looks good locally. I even show the "Server Connections: " at the bottom.
K7MVE
(Matt)
28 December 2021 10:13
#8
Logs show:
dp.server: Starting udp server
2021-12-27 23:16:45.644 INF udp.server: My IP Address: “0.0.0.0” My MAC Address: “E4:5F:01:6C:07:59”
2021-12-27 23:16:45.644 INF udp.server: Server Binding Control to: 50001
2021-12-27 23:16:45.644 INF udp.server: Server Binding CIV to: 50002
2021-12-27 23:16:45.644 INF system: Could not find Icom serial port. Falling back to OS default. Use --port to specify, or modify preferences.
2021-12-27 23:16:45.644 INF udp.server: Server Binding Audio to: 50003
K7MVE
(Matt)
28 December 2021 10:15
#9
Looks like it wants to bind to the wireless adapter based on "My MAC Address: “E4:5F:01:6C:07:59”
phil
(Phil Taylor M0VSE)
28 December 2021 10:18
#10
Hi Matt,
Wfview will bind the the ‘primary’ interface only. If you aren’t using wireless, I would recommend disabling it first.
K7MVE
(Matt)
#11
[Server]
ServerAudioPort=50003
ServerCivPort=50002
ServerControlPort=50001
ServerEnabled=true
ServerNumUsers=1
ServerPassword_0=(redacted)
ServerPassword_1=
ServerUserType_0=0
ServerUserType_1=0
ServerUsername_0=K7MVE
ServerUsername_1=
K7MVE
(Matt)
28 December 2021 10:20
#12
I have configured WLAN to see if it would work on that interface but no luck. Not sure how to completely disable it. Yet.
K7MVE
(Matt)
28 December 2021 10:25
#14
Was just going through that same site.
K7MVE
(Matt)
28 December 2021 10:30
#15
Looks like I hosed the network settings altogether. VNC is no longer accepting connections. I very much appreciate your time. I will take a look at it again next time I am up at my parent’s.
73’s
roeland
(Roeland Jansen)
28 December 2021 14:52
#16
maybe you should change your server password now Matt, unless you obfuscated it
ServerPassword_0=xxxxxxxx (redacted)
K7MVE
(Matt)
28 December 2021 18:18
#18
Thanks, roeland, I will do as soon as I get something to connect to it.
I have been able to get the wireless adapter disabled and the Pi back online. Logs on the Pi show the proper MAC but still show “My IP Address: 0.0.0.0”.
Logs on the client side show:
2021-12-28 09:22:24.315 INF system: “Starting wfview: build ea09647 on Jul 26 2021 at 11:23:33 by build@wfview.org ”
2021-12-28 09:22:24.316 INF system: “Operating System: Windows 10 Version 2009 (i386)”
2021-12-28 09:22:24.316 INF system: “Build Qt Version 5.15.2. Current Qt Version: 5.15.2”
2021-12-28 09:22:25.260 INF default: setState 1
2021-12-28 09:22:25.261 INF default: setState 0
2021-12-28 09:22:25.261 INF default: setState 1
2021-12-28 09:22:25.766 INF system: Loading settings from “\HKEY_CURRENT_USER\Software\wfview\wfview”
2021-12-28 09:22:25.853 INF gui: Got Audio Output: “”
2021-12-28 09:22:25.853 INF gui: Got Audio Input: “”
2021-12-28 09:22:25.862 INF default: Getting server config
2021-12-28 09:22:25.994 INF system: Cannot prepare WF view without rigCaps. Waiting on this.
2021-12-28 09:22:25.995 INF udp: Starting udpHandler user: “k7mve” rx latency: 150 tx latency: 150 rx sample rate: 48000 rx codec: 4 tx sample rate: 48000 tx codec: 4
2021-12-28 09:22:26.001 INF udp: Got IP Address : “[host url]” : “[correct host public address]”
2021-12-28 09:22:26.013 INF udp: UDP Stream bound to local port: 50690 remote port: 50001
2021-12-28 09:22:26.089 INF system: Received CommReady!!
2021-12-28 09:22:32.478 INF udp: Closing UDP stream : “[correct host public address]” : 50001
2021-12-28 09:22:32.479 INF udp: Starting udpHandler user: “k7mve” rx latency: 150 tx latency: 150 rx sample rate: 48000 rx codec: 4 tx sample rate: 48000 tx codec: 4
2021-12-28 09:22:32.480 INF udp: Got IP Address : “[host url]” : “[correct host public address]”
2021-12-28 09:22:32.481 INF system: Received CommReady!!
2021-12-28 09:22:32.486 INF udp: UDP Stream bound to local port: 65085 remote port: 50001
roeland
(Roeland Jansen)
28 December 2021 19:02
#19
I redacted the password in the both posts.
K7MVE
(Matt)
29 December 2021 17:07
#20
Thank you.
I think I am giving up.
I prepared a new card with a fresh version of plain Raspberry Pi OS
Booted Pi
Ran all updates
Set up network
Disabled WiFi
Configured RealVNC Server
Downloaded and ran script from fullbuild-wfview.sh · master · Elliott Liggett / scripts · GitLab
Started and configured Wfview
Restarted Wfview
Same exact issue with ports not opening and logs showing IP address of 0.0.0.0
K7MVE
(Matt)
29 December 2021 17:53
#21
Nevermind. Im making a big deal out of nothing. Installed/configured ZeroTier on Pi server and connected to it remotely using that. Connected right up with no issues. My issue is obviously has something to do with the port forwarding through my parent’s firewall. I prefer ZeroTier anyways.
