Possible Bug with Hotkeys F1-F4
Brief summary of problem (put in title as well): Hotkeys F1-F4 not working as I would expect
Radio Model: IC-7300
Operating System:
Tried to google it (Y/N/NA): N
What I did:
I am doing some evaluation for blind users and this seems confusing to me. I don’t know if their screen readers would help with this but it doesn’t work the way I would have expected.
Expected behavior:
I would have assumed that the function keys to switch between different tabs would work no matter which tab you are currently on. I am new to WFview and am guessing that this might have come in with 2.0… did it used to be a tab control instead of separate windows?
Observed behavior:
I found the function keys only worked when you are on the Main window. And F4 doesn’t seem to work at all.
You are correct. When we re-wrote large parts of the UI, we did not put all the hot keys into each widget. I suppose we can fix this for you though :slight_smile:
Hi Elliott,
My main interest in the interface is for those who are blind. I think this might be a bigger deal to them since a mouse is a useless device to them.
Thanks for your great software… hopefully you don’t mind me bugging the team for stuff like this.
Brian
KF0SMF
I don’t mind a bit, Brian. We’re happy to do simple things like this.
I have fixed the issue, F1-F4 will work in any window now. The exception is if there is not a radio connected, then we cannot open those widgets.
I also added Shift + F1-F7 as shortcuts within the Settings widget to navigate to each page.
This will all go in to the next release.
That’s awesome… Thanks again for all the great work everyone! :clap:
