I am trying to set up a remote connection for my IC7300. I have a server wfview running under debian bookworm and that is connecting to the IC7300 OK. I can control it using a VNC session OK.
I have a client connection on a W11 laptop. I can connect to the server OK and listen to the audio coming from the IC-7300. Unfortunately the CI-V connection is not working.
I attache the two log files for the client and server. The server is the file ending …454.log
It seems I can’t attach the document.
Client log:
2024-05-02 20:25:35.008 INF system: “wfview version: 1.64 (Git:b4c079f on Jul 16 2023 at 14:29:30 by build@wfview.org). Operating System: Windows 11 Version 23H2 (x86_64). Build Qt Version 6.5.1. Current Qt Version: 6.5.1”
2024-05-02 20:25:35.023 INF system: Loading settings from “C:/Users/pvros/AppData/Roaming/wfview/wfview/ic7300-wan”
2024-05-02 20:25:35.038 INF gui: Got Audio Output from Settings: “Speaker (Realtek(R) Audio)”
2024-05-02 20:25:35.039 INF gui: Got Audio Input from Settings: “Microphone Array (Intel® Smart Sound Technology for Digital Microphones)”
2024-05-02 20:25:35.059 INF cw: “Sidetone Output: Speaker (Realtek(R) Audio) (volume: 0 rate: 44100 type: 2”
2024-05-02 20:25:35.059 INF audio: Audio device(s) found (*=default)
2024-05-02 20:25:35.061 INF audio: * ( 0 ) Input Device : “CABLE-A Output (VB-Audio Cable A)”
2024-05-02 20:25:35.061 INF audio: ( 1 ) Input Device : “CABLE Output (VB-Audio Virtual Cable)”
2024-05-02 20:25:35.061 INF audio: ( 2 ) Input Device : “Microphone Array (Intel® Smart Sound Technology for Digital Microphones)”
2024-05-02 20:25:35.062 INF audio: ( 3 ) Input Device : “CABLE-B Output (VB-Audio Cable B)”
2024-05-02 20:25:35.065 INF audio: * ( 0 ) Output Device : “Speaker (Realtek(R) Audio)”
2024-05-02 20:25:35.065 INF audio: ( 1 ) Output Device : “CABLE Input (VB-Audio Virtual Cable)”
2024-05-02 20:25:35.065 INF audio: ( 2 ) Output Device : “CABLE-B Input (VB-Audio Cable B)”
2024-05-02 20:25:35.065 INF audio: ( 3 ) Output Device : “CABLE-A Input (VB-Audio Cable A)”
2024-05-02 20:25:35.065 INF default: Looking for inputs
2024-05-02 20:25:35.066 INF audio: "Client Audio input device Microphone Array (Intel® Smart Sound Technology for Digital Microphones) found! "
2024-05-02 20:25:35.066 INF default: Looking for outputs
2024-05-02 20:25:35.066 INF audio: "Client Audio output device Speaker (Realtek(R) Audio) found! "
2024-05-02 20:25:35.067 INF audio: “Server Audio input device CABLE-A Output (VB-Audio Cable A) found! "
2024-05-02 20:25:35.067 INF audio: “Server Audio output device Speaker (Realtek(R) Audio) found! "
2024-05-02 20:25:35.142 INF system: Cannot prepare WF view without rigCaps. Waiting on this.
2024-05-02 20:25:35.145 INF rig: creating instance of rigCommander()
2024-05-02 20:25:35.146 INF udp: Starting udpHandler user: “philip” rx latency: 150 tx latency: 150 rx sample rate: 48000 rx codec: 4 tx sample rate: 48000 tx codec: 4
2024-05-02 20:25:35.146 INF cluster: starting dxClusterClient()
2024-05-02 20:25:35.151 INF udp: UDP Stream bound to local port: 58880 remote port: 50001
2024-05-02 20:25:35.194 INF system: Received CommReady!!
2024-05-02 20:25:35.194 INF default: Setting rig state for wfmain
2024-05-02 20:25:35.647 INF udp: udpHandler : Received I am here from: QHostAddress(”::ffff:82.47.131.126”)
2024-05-02 20:25:35.662 INF udp: udpHandler : Received I am ready
2024-05-02 20:25:35.662 INF udp: udpHandler : Sending login packet
2024-05-02 20:25:35.662 INF udp: Got connection type: “WFVIEW”
2024-05-02 20:25:35.662 INF udp: udpHandler : Received matching token response to our request
2024-05-02 20:25:35.662 INF udp: udpHandler : Detected connection speed WFVIEW
2024-05-02 20:25:35.678 INF udp: udpHandler “Received radio capabilities, Name: IC-7300, Audio: ICOM_VAUDIO, CIV: 94, MAC: 00:90:c7:41:42:3a CAPF: 5001”
2024-05-02 20:25:35.678 INF udp: Got Connection status for: IC-7300 Busy: 0 Computer IP “0.0.0.0”
2024-05-02 20:25:35.678 INF udp: Got Radio 0
2024-05-02 20:25:35.678 INF udp: Find available local ports
2024-05-02 20:25:35.678 INF default: Received serial port baud rate from remote server: 115200
2024-05-02 20:25:35.678 INF system: Delay command interval timing: 75 ms
2024-05-02 20:25:35.725 INF udp: Starting udpCivData
2024-05-02 20:25:35.725 INF udp: UDP Stream bound to local port: 58881 remote port: 50002
2024-05-02 20:25:35.725 INF udp: Starting udpAudio
2024-05-02 20:25:35.725 INF udp: UDP Stream bound to local port: 58882 remote port: 50003
2024-05-02 20:25:35.725 INF udp: udpHandler Got serial and audio request success, device name: “IC-7300”
2024-05-02 20:25:35.725 INF udp: Got Connection status for: IC-7300 Busy: 1 Computer zephyr-wfview IP “82.47.131.126”
2024-05-02 20:25:35.725 INF audio: Output audio handler starting: “Speaker (Realtek(R) Audio)”
2024-05-02 20:25:35.725 INF audio: Input audio handler starting: “Microphone Array (Intel® Smart Sound Technology for Digital Microphones)”
2024-05-02 20:25:35.725 INF audio: Input thread id 0x19ec
2024-05-02 20:25:35.725 INF audio: Output thread id 0x1624
2024-05-02 20:25:35.725 INF audio: Output start() running
2024-05-02 20:25:35.725 INF audio: Input start() running
2024-05-02 20:25:35.725 INF audioconverter: Starting audioConverter() Input: 1 Channels of 0 48000 Int16 Output: 2 Channels of 0 48000 Float
2024-05-02 20:25:35.725 INF audioconverter: Starting audioConverter() Input: 2 Channels of 0 48000 Float Output: 1 Channels of 0 48000 Int16
2024-05-02 20:25:35.740 INF udp: udpAudio : Received I am here
2024-05-02 20:25:38.233 INF udp: CIV Watchdog: no CIV data received for 2s, requesting data start.
2024-05-02 20:26:33.405 INF audioconverter: Closing audioConverter() Input: 1 Channels of 0 48000 Int16 Output: 2 Channels of 0 48000 Float
2024-05-02 20:26:33.422 INF audioconverter: Closing audioConverter() Input: 2 Channels of 0 48000 Float Output: 1 Channels of 0 48000 Int16
2024-05-02 20:26:33.429 INF udp: Closing UDP stream : “82.47.131.126” : 50003
2024-05-02 20:26:33.429 INF udp: Closing UDP stream : “82.47.131.126” : 50002
2024-05-02 20:26:33.429 INF udp: Sending token removal packet
2024-05-02 20:26:33.429 INF udp: Closing UDP stream : “82.47.131.126” : 50001
2024-05-02 20:26:34.768 INF rig: closing instance of rigCommander()
2024-05-02 20:26:34.768 INF cluster: closing dxClusterClient()
Server log:
2024-05-02 20:24:54.847 INF system: “wfview version: 1.64 (Git:1805861 on Sep 3 2023 at 14:22:35 by philip@chinook). Operating System: Debian GNU/Linux 12 (bookworm) (x86_64). Build Qt Version 5.15.8. Current Qt Version: 5.15.8”
2024-05-02 20:24:54.874 INF system: Loading settings from “/home/philip/.local/share/wfview/wfview/ic7300”
2024-05-02 20:24:54.912 INF gui: Got Audio Output from Settings: “default”
2024-05-02 20:24:54.913 INF gui: Got Audio Input from Settings: “default”
2024-05-02 20:24:54.916 INF cw: “Sidetone Output: alsa_output.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.analog-stereo.2 (volume: 0 rate: 44100 size: 16 type: 1)”
2024-05-02 20:24:54.916 INF audio: Audio device(s) found (*=default)
2024-05-02 20:24:55.463 INF audio: * ( 0 “alsa” ) Input Device : “default”
2024-05-02 20:24:55.463 INF audio: ( 1 “alsa” ) Input Device : “sysdefault”
2024-05-02 20:24:55.463 INF audio: ( 2 “alsa” ) Input Device : “lavrate”
2024-05-02 20:24:55.463 INF audio: ( 3 “alsa” ) Input Device : “samplerate”
2024-05-02 20:24:55.463 INF audio: ( 4 “alsa” ) Input Device : “speexrate”
2024-05-02 20:24:55.463 INF audio: ( 5 “alsa” ) Input Device : “jack”
2024-05-02 20:24:55.463 INF audio: ( 6 “alsa” ) Input Device : “oss”
2024-05-02 20:24:55.463 INF audio: ( 7 “alsa” ) Input Device : “pulse”
2024-05-02 20:24:55.463 INF audio: ( 8 “alsa” ) Input Device : “speex”
2024-05-02 20:24:55.463 INF audio: ( 9 “alsa” ) Input Device : “upmix”
2024-05-02 20:24:55.463 INF audio: ( 10 “alsa” ) Input Device : “vdownmix”
2024-05-02 20:24:55.464 INF audio: ( 11 “alsa” ) Input Device : “hw:CARD=CODEC,DEV=0”
2024-05-02 20:24:55.464 INF audio: ( 12 “alsa” ) Input Device : “plughw:CARD=CODEC,DEV=0”
2024-05-02 20:24:55.464 INF audio: ( 13 “alsa” ) Input Device : “sysdefault:CARD=CODEC”
2024-05-02 20:24:55.464 INF audio: ( 14 “alsa” ) Input Device : “front:CARD=CODEC,DEV=0”
2024-05-02 20:24:55.464 INF audio: ( 15 “alsa” ) Input Device : “dsnoop:CARD=CODEC,DEV=0”
2024-05-02 20:24:55.464 INF audio: ( 16 “alsa” ) Input Device : “usbstream:CARD=CODEC”
2024-05-02 20:24:55.464 INF audio: ( 17 “alsa” ) Input Device : “hw:CARD=PCH,DEV=0”
2024-05-02 20:24:55.464 INF audio: ( 18 “alsa” ) Input Device : “plughw:CARD=PCH,DEV=0”
2024-05-02 20:24:55.464 INF audio: ( 19 “alsa” ) Input Device : “sysdefault:CARD=PCH”
2024-05-02 20:24:55.464 INF audio: ( 20 “alsa” ) Input Device : “front:CARD=PCH,DEV=0”
2024-05-02 20:24:55.464 INF audio: ( 21 “alsa” ) Input Device : “dsnoop:CARD=PCH,DEV=0”
2024-05-02 20:24:55.464 INF audio: ( 22 “alsa” ) Input Device : “usbstream:CARD=PCH”
2024-05-02 20:24:55.464 INF audio: ( 23 “alsa” ) Input Device : “hw:CARD=CODEC_1,DEV=0”
2024-05-02 20:24:55.464 INF audio: ( 24 “alsa” ) Input Device : “plughw:CARD=CODEC_1,DEV=0”
2024-05-02 20:24:55.464 INF audio: ( 25 “alsa” ) Input Device : “sysdefault:CARD=CODEC_1”
2024-05-02 20:24:55.464 INF audio: ( 26 “alsa” ) Input Device : “front:CARD=CODEC_1,DEV=0”
2024-05-02 20:24:55.464 INF audio: ( 27 “alsa” ) Input Device : “dsnoop:CARD=CODEC_1,DEV=0”
2024-05-02 20:24:55.464 INF audio: ( 28 “alsa” ) Input Device : “usbstream:CARD=CODEC_1”
2024-05-02 20:24:55.464 INF audio: ( 29 “default” ) Input Device : “alsa_input.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.analog-stereo”
2024-05-02 20:24:55.465 INF audio: ( 30 “default” ) Input Device : “alsa_output.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.analog-stereo.monitor”
2024-05-02 20:24:55.465 INF audio: ( 31 “default” ) Input Device : “alsa_output.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.analog-stereo.2.monitor”
2024-05-02 20:24:55.465 INF audio: ( 32 “default” ) Input Device : “alsa_input.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.analog-stereo.2”
2024-05-02 20:24:55.465 INF audio: ( 33 “default” ) Input Device : “alsa_input.pci-0000_00_1f.3.analog-stereo”
2024-05-02 20:24:55.465 INF audio: ( 34 “default” ) Input Device : “alsa_output.pci-0000_00_1f.3.analog-stereo.monitor”
2024-05-02 20:24:56.601 INF audio: * ( 0 “alsa” ) Output Device : “default”
2024-05-02 20:24:56.601 INF audio: ( 1 “alsa” ) Output Device : “sysdefault”
2024-05-02 20:24:56.601 INF audio: ( 2 “alsa” ) Output Device : “lavrate”
2024-05-02 20:24:56.601 INF audio: ( 3 “alsa” ) Output Device : “samplerate”
2024-05-02 20:24:56.601 INF audio: ( 4 “alsa” ) Output Device : “speexrate”
2024-05-02 20:24:56.601 INF audio: ( 5 “alsa” ) Output Device : “jack”
2024-05-02 20:24:56.601 INF audio: ( 6 “alsa” ) Output Device : “oss”
2024-05-02 20:24:56.602 INF audio: ( 7 “alsa” ) Output Device : “pulse”
2024-05-02 20:24:56.602 INF audio: ( 8 “alsa” ) Output Device : “speex”
2024-05-02 20:24:56.602 INF audio: ( 9 “alsa” ) Output Device : “upmix”
2024-05-02 20:24:56.602 INF audio: ( 10 “alsa” ) Output Device : “vdownmix”
2024-05-02 20:24:56.602 INF audio: ( 11 “alsa” ) Output Device : “hw:CARD=CODEC,DEV=0”
2024-05-02 20:24:56.602 INF audio: ( 12 “alsa” ) Output Device : “plughw:CARD=CODEC,DEV=0”
2024-05-02 20:24:56.602 INF audio: ( 13 “alsa” ) Output Device : “sysdefault:CARD=CODEC”
2024-05-02 20:24:56.602 INF audio: ( 14 “alsa” ) Output Device : “front:CARD=CODEC,DEV=0”
2024-05-02 20:24:56.602 INF audio: ( 15 “alsa” ) Output Device : “surround21:CARD=CODEC,DEV=0”
2024-05-02 20:24:56.602 INF audio: ( 16 “alsa” ) Output Device : “surround40:CARD=CODEC,DEV=0”
2024-05-02 20:24:56.602 INF audio: ( 17 “alsa” ) Output Device : “surround41:CARD=CODEC,DEV=0”
2024-05-02 20:24:56.602 INF audio: ( 18 “alsa” ) Output Device : “surround50:CARD=CODEC,DEV=0”
2024-05-02 20:24:56.602 INF audio: ( 19 “alsa” ) Output Device : “surround51:CARD=CODEC,DEV=0”
2024-05-02 20:24:56.602 INF audio: ( 20 “alsa” ) Output Device : “surround71:CARD=CODEC,DEV=0”
2024-05-02 20:24:56.602 INF audio: ( 21 “alsa” ) Output Device : “iec958:CARD=CODEC,DEV=0”
2024-05-02 20:24:56.602 INF audio: ( 22 “alsa” ) Output Device : “dmix:CARD=CODEC,DEV=0”
2024-05-02 20:24:56.602 INF audio: ( 23 “alsa” ) Output Device : “usbstream:CARD=CODEC”
2024-05-02 20:24:56.602 INF audio: ( 24 “alsa” ) Output Device : “hw:CARD=PCH,DEV=0”
2024-05-02 20:24:56.602 INF audio: ( 25 “alsa” ) Output Device : “hw:CARD=PCH,DEV=3”
2024-05-02 20:24:56.602 INF audio: ( 26 “alsa” ) Output Device : “hw:CARD=PCH,DEV=7”
2024-05-02 20:24:56.602 INF audio: ( 27 “alsa” ) Output Device : “hw:CARD=PCH,DEV=8”
2024-05-02 20:24:56.602 INF audio: ( 28 “alsa” ) Output Device : “plughw:CARD=PCH,DEV=0”
2024-05-02 20:24:56.602 INF audio: ( 29 “alsa” ) Output Device : “plughw:CARD=PCH,DEV=3”
2024-05-02 20:24:56.602 INF audio: ( 30 “alsa” ) Output Device : “plughw:CARD=PCH,DEV=7”
2024-05-02 20:24:56.602 INF audio: ( 31 “alsa” ) Output Device : “plughw:CARD=PCH,DEV=8”
2024-05-02 20:24:56.602 INF audio: ( 32 “alsa” ) Output Device : “sysdefault:CARD=PCH”
2024-05-02 20:24:56.602 INF audio: ( 33 “alsa” ) Output Device : “front:CARD=PCH,DEV=0”
2024-05-02 20:24:56.602 INF audio: ( 34 “alsa” ) Output Device : “surround21:CARD=PCH,DEV=0”
2024-05-02 20:24:56.602 INF audio: ( 35 “alsa” ) Output Device : “surround40:CARD=PCH,DEV=0”
2024-05-02 20:24:56.602 INF audio: ( 36 “alsa” ) Output Device : “surround41:CARD=PCH,DEV=0”
2024-05-02 20:24:56.602 INF audio: ( 37 “alsa” ) Output Device : “surround50:CARD=PCH,DEV=0”
2024-05-02 20:24:56.603 INF audio: ( 38 “alsa” ) Output Device : “surround51:CARD=PCH,DEV=0”
2024-05-02 20:24:56.603 INF audio: ( 39 “alsa” ) Output Device : “surround71:CARD=PCH,DEV=0”
2024-05-02 20:24:56.603 INF audio: ( 40 “alsa” ) Output Device : “hdmi:CARD=PCH,DEV=0”
2024-05-02 20:24:56.603 INF audio: ( 41 “alsa” ) Output Device : “hdmi:CARD=PCH,DEV=1”
2024-05-02 20:24:56.603 INF audio: ( 42 “alsa” ) Output Device : “hdmi:CARD=PCH,DEV=2”
2024-05-02 20:24:56.603 INF audio: ( 43 “alsa” ) Output Device : “dmix:CARD=PCH,DEV=0”
2024-05-02 20:24:56.603 INF audio: ( 44 “alsa” ) Output Device : “dmix:CARD=PCH,DEV=3”
2024-05-02 20:24:56.603 INF audio: ( 45 “alsa” ) Output Device : “dmix:CARD=PCH,DEV=7”
2024-05-02 20:24:56.603 INF audio: ( 46 “alsa” ) Output Device : “dmix:CARD=PCH,DEV=8”
2024-05-02 20:24:56.603 INF audio: ( 47 “alsa” ) Output Device : “usbstream:CARD=PCH”
2024-05-02 20:24:56.603 INF audio: ( 48 “alsa” ) Output Device : “hw:CARD=CODEC_1,DEV=0”
2024-05-02 20:24:56.603 INF audio: ( 49 “alsa” ) Output Device : “plughw:CARD=CODEC_1,DEV=0”
2024-05-02 20:24:56.603 INF audio: ( 50 “alsa” ) Output Device : “sysdefault:CARD=CODEC_1”
2024-05-02 20:24:56.603 INF audio: ( 51 “alsa” ) Output Device : “front:CARD=CODEC_1,DEV=0”
2024-05-02 20:24:56.603 INF audio: ( 52 “alsa” ) Output Device : “surround21:CARD=CODEC_1,DEV=0”
2024-05-02 20:24:56.603 INF audio: ( 53 “alsa” ) Output Device : “surround40:CARD=CODEC_1,DEV=0”
2024-05-02 20:24:56.603 INF audio: ( 54 “alsa” ) Output Device : “surround41:CARD=CODEC_1,DEV=0”
2024-05-02 20:24:56.603 INF audio: ( 55 “alsa” ) Output Device : “surround50:CARD=CODEC_1,DEV=0”
2024-05-02 20:24:56.603 INF audio: ( 56 “alsa” ) Output Device : “surround51:CARD=CODEC_1,DEV=0”
2024-05-02 20:24:56.603 INF audio: ( 57 “alsa” ) Output Device : “surround71:CARD=CODEC_1,DEV=0”
2024-05-02 20:24:56.603 INF audio: ( 58 “alsa” ) Output Device : “iec958:CARD=CODEC_1,DEV=0”
2024-05-02 20:24:56.603 INF audio: ( 59 “alsa” ) Output Device : “dmix:CARD=CODEC_1,DEV=0”
2024-05-02 20:24:56.603 INF audio: ( 60 “alsa” ) Output Device : “usbstream:CARD=CODEC_1”
2024-05-02 20:24:56.603 INF audio: ( 61 “default” ) Output Device : “alsa_output.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.analog-stereo.2”
2024-05-02 20:24:56.603 INF audio: ( 62 “default” ) Output Device : “alsa_output.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.analog-stereo”
2024-05-02 20:24:56.603 INF audio: ( 63 “default” ) Output Device : “alsa_output.pci-0000_00_1f.3.analog-stereo”
2024-05-02 20:24:56.603 INF default: Looking for inputs
2024-05-02 20:24:56.604 INF audio: "Client Audio input device default found! "
2024-05-02 20:24:56.604 INF default: Looking for outputs
2024-05-02 20:24:56.604 INF audio: "Client Audio output device default found! "
2024-05-02 20:24:56.605 INF audio: "Server Audio input device alsa_input.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.analog-stereo.2 found! "
2024-05-02 20:24:56.605 INF audio: "Server Audio output device alsa_output.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.analog-stereo.2 found! "
2024-05-02 20:24:56.686 INF system: Cannot prepare WF view without rigCaps. Waiting on this.
2024-05-02 20:24:56.689 INF rig: creating instance of rigCommander()
2024-05-02 20:24:56.689 INF cluster: starting dxClusterClient()
2024-05-02 20:24:56.689 INF udp.server: Starting udp server
2024-05-02 20:24:56.690 INF audio: Audio Input device “alsa_input.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.analog-stereo.2”
2024-05-02 20:24:56.690 INF audio: Audio Output device “alsa_output.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.analog-stereo.2”
2024-05-02 20:24:56.690 INF udp.server: My IP Address: “0.0.0.0”
2024-05-02 20:24:56.690 INF udp.server: Server Binding Control to: 50001
2024-05-02 20:24:56.690 INF udp.server: Server Binding CIV to: 50002
2024-05-02 20:24:56.691 INF udp.server: Server Binding Audio to: 50003
2024-05-02 20:24:56.691 INF serial: Opened port: “/dev/ttyUSB0”
2024-05-02 20:24:56.728 INF system: Received CommReady!!
2024-05-02 20:24:56.728 INF system: Delay command interval timing: 75 ms
2024-05-02 20:24:56.729 INF default: Setting rig state for wfmain
2024-05-02 20:24:56.731 INF rig: Using incomingCIVAddr: (int): 148 hex: “0x94”
2024-05-02 20:24:56.731 INF serial: Received rigCapabilities for “IC-7300”
2024-05-02 20:24:56.731 INF rig: Have rig ID: decimal: 148
2024-05-02 20:24:56.736 INF system: Delay command interval timing: 25 ms
2024-05-02 20:25:17.264 INF udp.server: “::ffff:192.168.0.11” : New Control connection created
2024-05-02 20:25:17.264 INF udp.server: “::ffff:192.168.0.11” ( “Control” ): Received ‘Are you there’
2024-05-02 20:25:17.271 INF udp.server: “::ffff:192.168.0.11” ( “Control” ): Received ‘Are you ready’
2024-05-02 20:25:17.278 INF udp.server: “::ffff:192.168.0.11” : Received ‘login’
2024-05-02 20:25:17.278 INF udp.server: “::ffff:192.168.0.11” : Incorrect username/password
2024-05-02 20:25:17.278 INF udp.server: “::ffff:192.168.0.11” ( “Control” ): Sending Login response: 1
2024-05-02 20:25:17.286 INF udp.server: “::ffff:192.168.0.11” : Received ‘disconnect’ request
2024-05-02 20:25:17.287 INF udp.server: Deleting “Control” connection to: “::ffff:192.168.0.11” : “58879”
2024-05-02 20:25:17.287 INF udp.server: Found “Control” connection to: “::ffff:192.168.0.11” : “58879”
2024-05-02 20:25:17.287 INF udp.server: Current Number of clients connected: 0
2024-05-02 20:25:35.344 INF udp.server: “::ffff:82.47.131.126” : New Control connection created
2024-05-02 20:25:35.345 INF udp.server: “::ffff:82.47.131.126” ( “Control” ): Received ‘Are you there’
2024-05-02 20:25:35.352 INF udp.server: “::ffff:82.47.131.126” ( “Control” ): Received ‘Are you ready’
2024-05-02 20:25:35.360 INF udp.server: “::ffff:82.47.131.126” : Received ‘login’
2024-05-02 20:25:35.360 INF udp.server: “::ffff:82.47.131.126” : User “philip” login OK
2024-05-02 20:25:35.361 INF udp.server: “::ffff:82.47.131.126” ( “Control” ): Sending Login response: 1
2024-05-02 20:25:35.368 INF udp.server: “::ffff:82.47.131.126” : Received create token request
2024-05-02 20:25:35.368 INF udp.server: “::ffff:82.47.131.126” ( “Control” ): Sending Capabilities : 2 for “IC-7300”
2024-05-02 20:25:35.368 INF udp.server: “::ffff:82.47.131.126” ( “Control” ): Client will have TX audio
2024-05-02 20:25:35.368 INF udp.server: “::ffff:82.47.131.126” ( “Control” ): Sending ConnectionInfo : 3
2024-05-02 20:25:35.379 INF udp.server: “::ffff:82.47.131.126” : Received request for radio connection
2024-05-02 20:25:35.379 INF udp.server: “::ffff:82.47.131.126” ( “Control” ): Sending Status
2024-05-02 20:25:35.379 INF udp.server: “::ffff:82.47.131.126” ( “Control” ): Sending ConnectionInfo : 5
2024-05-02 20:25:35.379 INF udp.server: “::ffff:82.47.131.126” : rxCodec: 4 txCodec: 4 rxSampleRate 48000 txSampleRate 48000 txBufferLen 150
2024-05-02 20:25:35.380 INF audio: Output audio handler starting: “alsa_output.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.analog-stereo.2”
2024-05-02 20:25:35.380 INF audio: Input audio handler starting: “alsa_input.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.analog-stereo.2”
2024-05-02 20:25:35.380 INF audio: Output thread id 0x7f0987fff6c0
2024-05-02 20:25:35.380 INF audio: Output start() running
2024-05-02 20:25:35.380 INF audio: Input thread id 0x7f0994b2d6c0
2024-05-02 20:25:35.380 INF audio: Input start() running
2024-05-02 20:25:35.380 INF audioconverter: Starting audioConverter() Input: 2 Channels of 0 48000 SignedInt 16 Output: 1 Channels of 0 48000 SignedInt 16
2024-05-02 20:25:35.381 INF audioconverter: Starting audioConverter() Input: 1 Channels of 0 48000 SignedInt 16 Output: 2 Channels of 0 48000 SignedInt 16
2024-05-02 20:25:35.434 INF udp.server: “::ffff:82.47.131.126” ( “Audio” ): New connection created
2024-05-02 20:25:35.434 INF udp.server: “::ffff:82.47.131.126” ( “Audio” ): Received ‘Are you there’
2024-05-02 20:25:35.440 INF udp.server: “::ffff:82.47.131.126” ( “Audio” ): Received ‘Are you ready’
2024-05-02 20:26:33.125 INF udp.server: “::ffff:82.47.131.126” : Received token disconnect request
2024-05-02 20:26:33.126 INF udp.server: “::ffff:82.47.131.126” ( “Control” ): Sending Token response for type: 1
2024-05-02 20:26:33.126 INF udp.server: “::ffff:82.47.131.126” : Received ‘disconnect’ request
2024-05-02 20:26:33.127 INF udp.server: Deleting “Audio” connection to: “::ffff:82.47.131.126” : “58882”
2024-05-02 20:26:33.127 INF udp.server: Found “Audio” connection to: “::ffff:82.47.131.126” : “58882”
2024-05-02 20:26:33.128 INF udp.server: Current Number of clients connected: 0
2024-05-02 20:26:33.128 INF audioconverter: Closing audioConverter() Input: 2 Channels of 0 48000 SignedInt 16 Output: 1 Channels of 0 48000 SignedInt 16
2024-05-02 20:26:33.129 INF audioconverter: Closing audioConverter() Input: 1 Channels of 0 48000 SignedInt 16 Output: 2 Channels of 0 48000 SignedInt 16
2024-05-02 20:26:33.130 INF udp.server: Deleting “Control” connection to: “::ffff:82.47.131.126” : “58880”
2024-05-02 20:26:33.130 INF udp.server: Found “Control” connection to: “::ffff:82.47.131.126” : “58880”
2024-05-02 20:26:33.131 INF udp.server: Current Number of clients connected: 0
2024-05-02 20:26:35.163 INF serial: Closing serial port: “ttyUSB0”
2024-05-02 20:26:37.060 INF rig: closing instance of rigCommander()
2024-05-02 20:26:37.060 INF udp.server: Closing udpServer
2024-05-02 20:26:37.061 INF cluster: closing dxClusterClient()
