Radio keyed by MMSSTV directly transmits no LAN audio - intended change from 2.24? (v3.0-beta3)
Brief summary of problem (put in title as well): Radio keyed by MMSSTV directly transmits no LAN audio - intended change from 2.24? (v3.0-beta3)
Radio Model: Icom IC-7610
Connectivity (USB/Ethernet/Wifi/Other): Ethernet (native Icom LAN), plus the radio’s USB cable for its serial ports
Operating System: Windows 10 22H2 (x64)
wfview version (press “About”): v3.0-beta3, built from source at tag v3.0-beta3 (Qt 6.10.3, MSVC 2022, x64)
What I did:
MMSSTV sends its audio to wfview through Virtual Audio Cable (wfview TX input = VAC Line 2, audio to the radio over LAN; radio in USB-D1 with DATA1 MOD = LAN). MMSSTV keys the radio itself, with RTS on the IC-7610’s own USB serial port (USB SEND), not through wfview. This setup works with wfview 2.24.
Expected behavior:
The radio transmits MMSSTV’s audio, as it did with 2.24.
Observed behavior:
The radio keys, and wfview’s TX level meter shows MMSSTV’s audio, but there is no modulation (carrier only, no RF from the audio).
wfview’s audio diagnostics show that during the transmission no TX audio is forwarded and no TX audio packets are sent to the radio. In v3, MainController::updateLocalTxForwarding() only forwards local input audio to the radio while a PTT that wfview knows about owns TX audio:
// USB output whenever no other source owns TX audio; network audio only
// while local PTT owns it.
toRig = micBridge && network &&
        m_txAudioArbiter.activeSource() == TxAudioInput::LocalInput;
That PTT can be the wfview Transmit button, rigctld, TCI, or a CI-V transmit command sent through wfview’s virtual serial port. When the radio is keyed any other way (USB SEND/RTS/DTR, foot switch, front panel, sequencer), it only updates the TX indicator; PttOrigin::Radio exists but nothing uses it to take TX audio. 2.24 sent TX audio all the time, so hardware keying worked.
Confirmed on the radio:
  • MMSSTV PTT on the radio’s COM port: no modulation.
  • MMSSTV PTT off, keyed with wfview’s Transmit button: modulation present, clean TX packets.
  • MMSSTV keying by CI-V (FE FE 98 E0 1C 00 01 FD) through wfview’s virtual serial port: modulation present. This is the workaround I am using now.
Question: is this an intended change? If so, it is a breaking change for anyone who keys the radio in hardware and would be worth a note in the release notes or manual. Some type of diagnostic available to the user to troubleshoot audio forwarding issues might also be appropriate, since it is difficult to understand by looking at the GUI why audio that appears as a valid, changing level on the LAN level meter is not making it to the radio.
If this is not an intended change, one option would be to also forward local input audio when no other source owns TX audio (as 2.24 effectively did; the radio ignores LAN audio while receiving). Reacting to the radio’s own TX status instead would be too late for modes like SSTV, as wfview learns of it by polling and the start of the transmission (the VIS header) would be lost.
AI disclosure: diagnosed with Claude Code (Anthropic, Claude Opus 5.5), using wfview’s MCP audio diagnostics and logs.
I tested everything above on my IC-7610.
Again, thanks for your work on wfview. Having it be open source makes it possible to understand obscure issues like this and fix them!
WD9U/Mark
Hi Mark,
The issue is that wfview does not even know which audio source to pass on to LAN if it does not know where the PTT came from.
Why not send the audio over USB directly to the rig, since the rig is connected via USB? That’s my recommendation.
I hate to be the “you’re holding it wrong” guy, but I think if you’ve got a physical connection to the radio and you’re keying it at the radio, you may as well send the audio that way too.
BTW there is a new SSTV app. I haven’t tested the SSTV capability, but it uses TCI and goes straight into wfview, without virtual audio cables or other control mechanisms.
I merged your other changes to our main branch. I might push out another beta build, or just clone and built it.
--E
