I’ve configured my station as a server on a 4gb Raspberry P4, with a LAN client on Windows 10. Both devices are hardwired to a 1gb Netgear switch with static IPs. Everything is working great with the exception of transmit audio to the IC-7300. I’ve tried multiple USB headseats on the client, as well as creating virtual audio cables with PulseAudio on the Pi, to no avail. My settings are…
RX Audio input on the PI: alsa_input.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.analog-stereo
TX Audio output on the PI: alsa_output.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.analog-stereo
Audio on both sides is QT Audio.
RX & TX codecs on the client are both Opus 1ch.
Both Audio Input & Output on the Pi are set to USB Audio Codec.
Server Default Control, CIV, and Audio ports of: 50001, 50002, & 50003.
Any suggestions or troubleshooting tips would be welcome.
Thanks for the reply! 1.52 on the Pi, 1.5 on Windows. HOWEVER, no sooner did I post this and I decided to switch the Audio System to “Port Audio” on both sides. While I’ve not listened to the audio as yet, it is working!
Glenn
No sooner did I post this and I decided to switch the Audio System to “Port Audio” on both sides. While I’ve not listened to the audio as yet, it is working!
Glenn
