RC-28 doesn't work.
Hello All
Love the program! Only issue I have is when I try and setup USB device. It reports no
USB controller found. The RC-28 is discovered as shown in log below.
Thanks in advance for any assistance!
73
K5AKM
Log File:
2023-05-07 11:48:39.735 INF system: “wfview version: 1.62 (Git:3fa14eb on Mar 12 2023 at 15:51:31 by build@wfview.org). Operating System: Windows 10 Version 2009 (x86_64). Build Qt Version 6.3.2. Current Qt Version: 6.3.2”
2023-05-07 11:48:39.780 INF system: Loading settings from “\HKEY_CURRENT_USER\Software\wfview\wfview”
2023-05-07 11:48:39.812 INF rigctld: started on port 4533
2023-05-07 11:48:39.813 INF gui: Got Audio Output from Settings: “Speakers (Realtek High Definition Audio)”
2023-05-07 11:48:39.813 INF gui: Got Audio Input from Settings: “IC-7300 Receive (6- USB Audio CODEC )”
2023-05-07 11:48:39.895 INF cw: “Sidetone Output: Speakers (Realtek High Definition Audio) (volume: 0 rate: 44100 type: 2”
2023-05-07 11:48:39.896 INF usbcontrol: Starting usbController()
2023-05-07 11:48:39.897 INF usbcontrol: “Compile-time version matches runtime version of hidapi: 0.13.1”
2023-05-07 11:48:39.897 INF usbcontrol: Found available HID devices (not all will be suitable for use):
2023-05-07 11:48:39.916 INF audio: Audio device(s) found (*=default)
2023-05-07 11:48:39.921 INF audio: * ( 0 ) Input Device : “IC-7300 Receive (6- USB Audio CODEC )”
2023-05-07 11:48:39.921 INF audio: ( 1 ) Input Device : “Stereo Mix (Realtek High Definition Audio)”
2023-05-07 11:48:39.921 INF audio: ( 2 ) Input Device : “Line 3/4 (M-Audio Delta 44)”
2023-05-07 11:48:39.921 INF audio: ( 3 ) Input Device : “Line (USB AUDIO CODEC)”
2023-05-07 11:48:39.921 INF audio: ( 4 ) Input Device : “Line 1/2 (M-Audio Delta 44)”
2023-05-07 11:48:39.921 INF audio: ( 5 ) Input Device : “Multichannel (M-Audio Delta 44)”
2023-05-07 11:48:39.921 INF audio: ( 6 ) Input Device : “Monitor (M-Audio Delta 44)”
2023-05-07 11:48:39.930 INF audio: * ( 0 ) Output Device : “Speakers (Realtek High Definition Audio)”
2023-05-07 11:48:39.930 INF audio: ( 1 ) Output Device : “LG FULL HD (Intel(R) Display Audio)”
2023-05-07 11:48:39.930 INF audio: ( 2 ) Output Device : “Multichannel (M-Audio Delta 44)”
2023-05-07 11:48:39.930 INF audio: ( 3 ) Output Device : “Line 3/4 (M-Audio Delta 44)”
2023-05-07 11:48:39.930 INF audio: ( 4 ) Output Device : “SIgnalink to 706mk2g (USB AUDIO CODEC)”
2023-05-07 11:48:39.930 INF audio: ( 5 ) Output Device : “Line 1/2 (M-Audio Delta 44)”
2023-05-07 11:48:39.930 INF audio: ( 6 ) Output Device : “IC-7300 Transmit (6- USB Audio CODEC )”
2023-05-07 11:48:39.930 INF audio: ( 7 ) Output Device : “Sceptre N43 (Intel(R) Display Audio)”
2023-05-07 11:48:39.930 INF default: Looking for inputs
2023-05-07 11:48:39.931 INF audio: "Client Audio input device IC-7300 Receive (6- USB Audio CODEC ) found! "
2023-05-07 11:48:39.931 INF default: Looking for outputs
2023-05-07 11:48:39.932 INF audio: "Client Audio output device Speakers (Realtek High Definition Audio) found! "
2023-05-07 11:48:39.933 INF audio: "Server Audio input device Line (USB AUDIO CODEC) found! "
2023-05-07 11:48:39.933 INF audio: "Server Audio output device IC-7300 Transmit (6- USB Audio CODEC ) found! "
2023-05-07 11:48:39.952 INF usbcontrol: “Device found: (046d:c52b) USB Receiver manufacturer: (USB Receiver)Logitech usage: 0x0004 usage_page 0xff00”
2023-05-07 11:48:39.952 INF usbcontrol: “Device found: (08bb:29c6) USB AUDIO CODEC manufacturer: (USB AUDIO CODEC)BurrBrown from Texas Instruments usage: 0x0001 usage_page 0x000c”
2023-05-07 11:48:39.952 INF usbcontrol: “Device found: (08bb:2901) USB Audio CODEC manufacturer: (USB Audio CODEC )Burr-Brown from TI usage: 0x0001 usage_page 0x000c”
2023-05-07 11:48:39.952 INF usbcontrol: “Device found: (046d:c52b) USB Receiver manufacturer: (USB Receiver)Logitech usage: 0x0002 usage_page 0x0001”
2023-05-07 11:48:39.952 INF usbcontrol: “Device found: (046d:c52b) USB Receiver manufacturer: (USB Receiver)Logitech usage: 0x0001 usage_page 0xff00”
2023-05-07 11:48:39.952 INF usbcontrol: “Device found: (046d:c52b) USB Receiver manufacturer: (USB Receiver)Logitech usage: 0x0001 usage_page 0x000c”
2023-05-07 11:48:39.952 INF usbcontrol: “Device found: (046d:c52b) USB Receiver manufacturer: (USB Receiver)Logitech usage: 0x0080 usage_page 0x0001”
2023-05-07 11:48:39.952 INF usbcontrol: “Device found: (046d:c52b) USB Receiver manufacturer: (USB Receiver)Logitech usage: 0x0088 usage_page 0xffbc”
2023-05-07 11:48:39.952 INF usbcontrol: “Device found: (0c26:001e) Icom RC-28 REMOTE ENCODER manufacturer: (Icom RC-28 REMOTE ENCODER)Icom Inc. usage: 0x0004 usage_page 0x0006”
2023-05-07 11:48:39.952 INF usbcontrol: “Device found: (046d:c52b) USB Receiver manufacturer: (USB Receiver)Logitech usage: 0x0006 usage_page 0x0001”
2023-05-07 11:48:39.952 INF usbcontrol: “Device found: (046d:c52b) USB Receiver manufacturer: (USB Receiver)Logitech usage: 0x0002 usage_page 0xff00”
2023-05-07 11:48:40.264 INF system: Cannot prepare WF view without rigCaps. Waiting on this.
2023-05-07 11:48:40.272 INF rig: creating instance of rigCommander()
2023-05-07 11:48:40.273 INF cluster: starting dxClusterClient()
2023-05-07 11:48:40.281 INF serial: Opened port: “COM3”
2023-05-07 11:48:40.296 INF rig: Warning: Spectrum sequence max was zero, yet spectrum was received.
2023-05-07 11:48:40.318 INF rig: Warning: Spectrum sequence max was zero, yet spectrum was received.
2023-05-07 11:48:40.339 INF rig: Warning: Spectrum sequence max was zero, yet spectrum was received.
2023-05-07 11:48:40.362 INF rig: Warning: Spectrum sequence max was zero, yet spectrum was received.
2023-05-07 11:48:40.383 INF rig: Warning: Spectrum sequence max was zero, yet spectrum was received.
2023-05-07 11:48:40.392 INF system: Received CommReady!!
2023-05-07 11:48:40.392 INF system: Delay command interval timing: 75 ms
2023-05-07 11:48:40.392 INF default: Setting rig state for wfmain
2023-05-07 11:48:40.395 INF rig: Using incomingCIVAddr: (int): 148 hex: “0x94”
2023-05-07 11:48:40.396 INF serial: Received rigCapabilities for “IC-7300”
2023-05-07 11:48:40.396 INF rig: Have rig ID: decimal: 148
2023-05-07 11:48:40.474 INF rigctld: Got rigcaps for: “IC-7300”
2023-05-07 11:48:40.476 INF system: Delay command interval timing: 25 ms
2023-05-07 11:48:40.477 INF rig: Using incomingCIVAddr: (int): 148 hex: “0x94”
2023-05-07 11:48:40.477 INF serial: Received rigCapabilities for “IC-7300”
2023-05-07 11:48:40.477 INF rig: Have rig ID: decimal: 148
Hi
Unfortunately, when we released v1.62 I didn’t notice that I had broken support for the RC28!
You can download v1.61 from https://wfview.org/older-downloads/ which should work, there aren’t many changes between the two versions (mainly extra USB controllers and fixes to the CW window)
