Hello,
Big problems.
My W10 pc conked out after a power glitch, but I was, with a lot of work, able to re-install Windows and get most things going again.
Wiped everything out in the way of programs, etc., so had to re-instll WfView.
a. Re-installed WfView (one of my favorite programs) (using with an Icom R8600), but can’t get it to connect to the radio, or work.
Using LAN. (NETWORK selected in Settings)
During the install, I had an error msg:
Istallation Error. Error during installation process (org.wfview.wfview). Cannot Start: "C:\Progra Files (X86\wfview\vc_redist.x86.exe/passive/norestart"
Process failed to start: The system cannot find the file specified
So, is this my problem ?
What is it saying ? Is it important ?
What should I do ?
b. The graphic that comes up cannot be re-sized or the edges dragged in VIEW.
But, surprisingly, in can in SETTINGS
Is this an improper Resolution setting in the W10 preferences, or…?
If so, what should it be set to, or how to correct, please ?
Much thanks; really appreciate the help,
Bob
