Repeaters Programing
Hello All
Just managed to set up a remote transceiver the only hitch was that I only set up one port forward, after I set up the other two it all worked…However…
Anyone know how to set up presets for repeaters or access the memory on the transceiver for repeaters if not how do you set up a new repeater?
After set up can you return to the same repeater or is it a one time setting to be lost on return?
I was going to purchase the BA1 software but may stay with this and give a donation.
Any help greatly appreciated.
Thank you
PS This maybe a future development request.
What radio?
In any case:
Hello Eliggett
Thank you for the information.
I did sort of look at the options but unable to get to the repeater lists as I would with the call button.
I did get to the preset memory stations of the radio but not the repeater lists under say for example UHF Repeaters.
My best guess is that the program only goes to the preset memory option and not the repeater lists.
My radio is Icom 9700.
Thank you
Clive.
Yes wfview does nothing with the repeater lists as Icom don’t expose this information over the C-IV interface, only memories.
Ah Ha
That answers why I am unable to access the repeater list.
Thank you.
I will have to start investigations on setting up the repeaters in the memory and not in the repeater lists.
I must admit I have been a little lazy and relying on the preset repeater list (or stored the new ones within the repeater lists) flicking through the ones not in range, which in it’s self tiresome.
Again thank you all for your help.
Kind regards
Clive.
