Radio Model:IC-7300
Connectivity (USB/Ethernet/Wifi/Other): Wifi
Operating System: Windows 11
wfview version (press “About”):2.05 (wfview-master64-20250324–05-00-01)
Checked the wfview manual (Y/N): y
Checked the wfview FAQ (Y/N): y
Tried to google it (Y/N/NA): N
I noticed the following: the S-Meter has no scale, except for the initial 0. I also noticed this in the build wfview-master64-20250317–05-00-01.
In the meantime, I checked the rig file and, indeed, I didn’t have the latest version. I replaced it, and everything works perfectly. Thank you very much for your support!
This is indeed an issue when using the daily/weekly builds, as some support files may also have required updates. We are working on a method of updating rig files from within wfview.
