Upgraded to ubuntu 22.04.02 LTS and displays a segmentation fault when opening wfview. Occurs with both the default install from the Ubuntu repository and installing from the install.sh script from the downloaded .deb file.
Ron
Ron
Hi Ron,
Can you make sure you deleted the .deb wfview entirely from your system, and then try our build script?
Thanks It worked after I reinstalled the libudev-dev package. Used:
sudo apt-get install --reinstall libudev-dev
and it now compiled without error and works.
Thanks.
Ron
Excellent, glad to hear it!
