I’m running wfview on my desktop PC, and it’s connecting fine to my IC-7300.
I have enabled the Radio Server specifying ports 50110,50111, 50112.
I have forwarded the 3 ports to my desktop PC ip address of 192.168.1.10
When I run netscan -aon on command prompt, my 3 ports are showing attached to IP Address 0.0.0.0 instead of 192.168.1.10
Whats happening here?
Here is my log
2023-11-22 13:15:37.972 INF system: “wfview version: 1.64 (Git:1805861 on Nov 20 2023 at 03:03:22 by build@wfview.org). Operating System: Windows 11 Version 22H2 (x86_64). Build Qt Version 6.3.2. Current Qt Version: 6.5.1”
2023-11-22 13:15:38.006 INF system: Loading settings from “\HKEY_CURRENT_USER\Software\wfview\wfview”
2023-11-22 13:15:38.146 INF rigctld: started on port 4533
2023-11-22 13:15:38.147 INF gui: Got Audio Output from Settings: “LG TV (NVIDIA High Definition Audio)”
2023-11-22 13:15:38.147 INF gui: Got Audio Input from Settings: “Microphone (USB Audio CODEC )”
2023-11-22 13:15:38.266 INF cw: “Sidetone Output: LG TV (NVIDIA High Definition Audio) (volume: 0 rate: 44100 type: 2”
2023-11-22 13:15:38.267 INF audio: Audio device(s) found (*=default)
2023-11-22 13:15:38.275 INF audio: * ( 0 ) Input Device : “Microphone (USB Audio CODEC )”
2023-11-22 13:15:38.275 INF audio: ( 1 ) Input Device : “Microphone (USB Audio Device)”
2023-11-22 13:15:38.285 INF audio: * ( 0 ) Output Device : “LG TV (NVIDIA High Definition Audio)”
2023-11-22 13:15:38.285 INF audio: ( 1 ) Output Device : “Speakers (USB Audio CODEC )”
2023-11-22 13:15:38.285 INF audio: ( 2 ) Output Device : “Speakers (USB Audio Device)”
2023-11-22 13:15:38.285 INF default: Looking for inputs
2023-11-22 13:15:38.286 INF audio: "Client Audio input device Microphone (USB Audio CODEC ) found! "
2023-11-22 13:15:38.286 INF default: Looking for outputs
2023-11-22 13:15:38.286 INF audio: "Client Audio output device LG TV (NVIDIA High Definition Audio) found! "
2023-11-22 13:15:38.288 INF audio: "Server Audio input device Microphone (USB Audio Device) found! "
2023-11-22 13:15:38.288 INF audio: "Server Audio output device Speakers (USB Audio Device) found! "
2023-11-22 13:15:38.537 INF system: Cannot prepare WF view without rigCaps. Waiting on this.
2023-11-22 13:15:38.546 INF rig: creating instance of rigCommander()
2023-11-22 13:15:38.547 INF cluster: starting dxClusterClient()
2023-11-22 13:15:38.547 INF udp.server: Starting udp server
2023-11-22 13:15:38.547 INF audio: Audio Input device “Microphone (USB Audio Device)”
2023-11-22 13:15:38.547 INF audio: Audio Output device “Speakers (USB Audio Device)”
2023-11-22 13:15:38.553 INF serial: Opened port: “COM5”
2023-11-22 13:15:38.574 INF udp.server: My IP Address: “192.168.1.10”
2023-11-22 13:15:38.574 INF udp.server: Server Binding Control to: 50110
2023-11-22 13:15:38.574 INF udp.server: Server Binding CIV to: 50111
2023-11-22 13:15:38.575 INF udp.server: Server Binding Audio to: 50112
2023-11-22 13:15:38.626 INF system: Received CommReady!!
2023-11-22 13:15:38.626 INF system: Delay command interval timing: 75 ms
2023-11-22 13:15:38.626 INF default: Setting rig state for wfmain
2023-11-22 13:15:38.628 INF rig: Using incomingCIVAddr: (int): 148 hex: “0x94”
2023-11-22 13:15:38.629 INF serial: Received rigCapabilities for “IC-7300”
2023-11-22 13:15:38.629 INF rig: Have rig ID: decimal: 148
2023-11-22 13:15:38.639 INF rigctld: Got rigcaps for: “IC-7300”
2023-11-22 13:15:38.641 INF system: Delay command interval timing: 25 ms
2023-11-22 13:15:39.238 INF system: Could not find modulation input: 2
2023-11-22 13:15:39.924 INF system: Could not find modulation input: 2
2023-11-22 13:33:40.327 INF log: Sending data to termbin.com. Standby.
2023-11-22 13:33:40.367 INF log: Connected to logging host
2023-11-22 13:33:40.448 INF log: Receiving data from logging host.
2023-11-22 13:33:40.448 INF log: Sent log to URL: “HTTP/1.1 303 See Other\r\nLocation: Malwarebytes close”
2023-11-22 13:33:40.449 INF log: This address already copied to the clipboard. Please paste this URL in to your support questions.
2023-11-22 13:33:41.462 INF log: Disconnected from logging host
2023-11-22 13:35:39.139 INF log: Sending data to termbin.com. Standby.
2023-11-22 13:35:39.198 INF log: Connected to logging host
2023-11-22 13:35:39.198 INF log: Receiving data from logging host.
2023-11-22 13:35:39.199 INF log: Sent log to URL: “HTTP/1.1 303 See Other\r\nLocation: Malwarebytes close”
2023-11-22 13:35:39.199 INF log: This address already copied to the clipboard. Please paste this URL in to your support questions.
2023-11-22 13:35:40.188 INF log: Disconnected from logging host
