Does anyone know if RS-BA1 provides a user with remote access to an IC-7300’s Menu system? I do see that there is a Set Mode button at the top of the screen. Just wondering if it does what I’m hoping it does!
hello Alexander, with RS-BA1 from the Icom Remote Utility function you can make your rtx communicate even remotely and create a connection itself. The only problem that seems fun only with Icom. I did tests by creating an LAn connection by looking in which ways far to dialogue WF with RS.BA1 but I was not successful. 73 Ale IZ4OSH
no you cannot access the 7300 menu, you can only access some functions such as the rtty menu to set the macros. RS-ba is very limited. Even a few I performed a remote connection test by creating a server, keeping the debug page open I see that RSBA does not connect, WF sees the connection. I think I miss more information. Today I will do other tests if it works with this system all even long-standing rtx icoms can connect to WFview.
That’s a shame. Luckily, several of wfview’s settings are the same for Win4Icom Suite so maybe there’s a combination of settings that will work for both.
If there’s a specific setting that you need one way for win4icom and another way for wfview, please do let us know. Maybe we can manually set some things in wfview for you on startup.
I’ll give you one tip, and this is “beta” information, but if you can’t keep CI-V Transceive on, it is ok, so long as in wfview you manually set the CI-V address, save settings, and re-launch wfview. With the manual address, wfview will find the radio right away.
Since you’re not physically at the radio, having CI-V Transceive off won’t have much effect on your usage.
These appear to be the only settings changes that Win4Icom Suite requires me to make:
Set > Connectors > CI-V > CIV-USB Port = “Unlink from [REMOTE]”
Set > Connectors > CI-V > CI-V USB Baud Rate = 115200
No mention of CI-V transceive, so I assume it is at whatever the factory default is. Looks like I made a mountain our of a mole hill and wasted a lot of peoples’ time. Chalk it up to fear of the unknown; I hate messing with a system that works! I’ll install wfview and let you know how it goes!
Yes we are aware that RSBA1 does this, we are keen for wfview to not change any settings in the radio that may cause issues with other software though!
Those two settings for Win4Icom are also required for wfview, so you’re good there!
wfview can operate ok without CI-V Transceive, you will just have to supply the CI-V address to wfview and also understand that using the rig physically while using wfview at the same time may produce some inconsistent results. That shouldn’t be a problem for remote users though. In other words, CI-V Transceive could be on or off, not a big deal.
