Simultaneous work wfview and other CIV-interface ?
Is it possible to operate the IC-705 with WFVIEW remotely and simultanously use the CIV interface on the IC-705 e.g. with an RaspberryPI .
I would like to program an additional web interface with a raspberryPi that implements a tune function; like: save current state, switch to Cw mode, power to 10 watts, send some time, then switch back to the last state.
With Regards
Heribert , dk2jk
Please see our manual under “sharing control”. You can use the pseudo terminal device as if it were the radio’s CI-V port. This lets you run whatever commands you wish while wfview is running.
