I’m sure it’s something really dumb on my part, as usual, but just cannot find my problem.
Everything was fine, until I shut off pc, and re-booted last night.
Have downloaded a brand new copy, just to be sure, but…
Am hoping someone might give me a suggestion on what to check.
Have put a lot of hours into this, and am truly stumped.
Using an Icom R8600.
Program talked thru LAN when it worked previously.
On the Settings menu, I have all the LAN boxes filled out, apparently the same as before.
Network is selected.
Under Radio Status Tab, there is nothing filled in ?
Should there be ? I don’t remember what it had before.
I click Save Settings,and Connect
Power On or Power Off does not communicate with the radio.
Spectrum and Waterfall are blank.
In View, Radio Status again shows all blanks.
I am pretty much convinced, but not 100%, that my problem is probably
some setting in the radio. If so, I have no idea what; nothing seems different from last time.
LAN problem ?
Would be most appreciative for any thoughts, radio setting to check, LAN settings to check, etc.
As always,
Much thanks,
Bob
