It was noticed that the interface simultaneously displays “Power On” and “Power Off.” It is recommended to keep only one button to indicate the current state. When the machine is off, the button should display “Power Off.” When the machine is on, the button should display “Power On” and use a slightly brighter background color to indicate that the device is active, similar to “Connect to Radio.” The space saved could be used to place the “Connect to Radio” button.
We’ll consider it next time we are editing the UI.
thanks.
By the way, I noticed that the software currently does not support Simplified Chinese (zh_CN). Could you add the corresponding .ts
file? I can take care of the subsequent Chinese translation.
Sure! I will generate a template file. Thanks!!
Ok, here it is:
https://gitlab.com/eliggett/wfview/-/blob/master/translations/wfview_zh_CN.ts?ref_type=heads
We are always thankful for translations!
The localization work has been basically completed. A PR has been submitted; please review it.
cool, I merged it.
Roeland
