Operating System: Win 11
Method of download attempted (from wfview.org, package manager, source code, etc): Install file from WFview.org
Radio Make and Model: Icom IC-7100
Method of radio connectivity (USB, WiFi, Ethernet, etc):
Did you check the FAQ? Yes
I suspect this to be a network problem but I’m hoping someone can point me in the right direction.
I have remote setup running server software on a laptop on the remote site. Everything works fine, except that the sound is stable for only 11 seconds, gets choppy with a great number of packet losses for 3-4 seconds, and then 11 seconds of stable sound again. And so it keeps going…
I had the setup running stable in-house on my LAN.
I have tested from different locations (different nets) and two different clients without results. So i guess it,s something with my 4G router on the remote site.
I’ve spent hours trying to figure this out without any success, so all ideas are most welcome.
Thank you for the help.
I switched from QT to PortAudio and that made a huge difference. I still have packet losses every 11 seconds, but the PortAudio seems to cope with it far better.
