Sound not working on Ts-890 with wfview 2.10, and Mac OS
hi there,
I’m not getting any audio after connecting to the ts-890. I’m using the QT audio codec, and no audio is coming out of the Macbook pro speakers. I’ve tried changing outputs, and then reselected the default, and have had no result. “Uncategorized” Please consider selecting a category from the menu above on the right.
Read the manual (y/n)?
Read the FAQ (y/n)?
What version of MacOS? I had lots of issues getting it to work with Sequoia, you will need to make sure that ‘Local Network’ is enabled for wfview within ‘Privacy & Security’
I just tried connecting to the TS-890 on my Mac and it looks like audio isn’t working, so I will need to investigate further. It is possible that (yet another) MacOS update has broken it!
Audio works fine on my Windows machine.
hi there, I’m running sequoia 15.4.1 on both machines.
Well that’s a strange one…
I have found the issue and pushed a fix to the master development branch, basically some fairly generic code that works fine in Windows and Linux, doesn’t work in MacOS. I have changed it to work in a slightly different way and that now works!
We have discovered another small (unrelated) issue that we have fixed, so after a couple of days, we will likely make another release.
