Hello,
Wonderful program.
Thanks so much for making it available.
I am about 100% sure that this option exists, but
just cannot find out how to do it.
Have read the Manual, and experimented, much, really.
For the Spectrum Display, how can I get the “portion” underneath the
actual spectrum to fill in with a selectable solid color ?
Bob
eliggett
(Elliott Liggett)
19 June 2025 21:33
2
Just set a color for the Underlay Fill. Make sure it’s not transparent.
Bob:
Bob
Thanks.
Appreciate the help.
Bob
eliggett
(Elliott Liggett)
20 June 2025 21:09
4
Hi Bob,
I meant to say:
“Just set a color for the Spectrum Fill . Make sure it’s not transparent.”
The “fill” colors are colors that fill the plot from the plotted data line to the lower axis.
Thanks for the “hand-holding” with this.
Will blame my questions on old-age now; a great excuse for most
anything.
Wonderful program.
Using with an Icom R8600 on a mac.
Can’t imagine how many hours you’ve put into its development.
Question please:
The ability to elect an Antenna (1, 2, or 3) seems “flaky”.
Sometimes it will allow me to make a selection, other times it will not.
This is true even if I limit to freq’s under 30 MHz.
*It would be good if the ability to select Ant. 1, 2, or 3 be available, I think, irrespective
of frequency. (Below and/or above 30 MHz)
What, as usual, am I missing ?
BTW: The Memories work just great. Really nice.
Best regards,
Bob. rgsrose@comcast.net
phil
(Phil Taylor M0VSE)
21 June 2025 14:02
6
This has been covered a number of times. The radio ONLY allows selection of antenna below 30MHz, this is a limitation of the radio and will not change (unless Icom do it!)
Currently you must be within an amateur band below 30MHz to change the antenna, this is something we are hoping to fix, but the 30MHz limit will always apply.
Thanks.
Good explanation.
Regards,
Bob
