Try “Center” mode and see if it fixes the issue. Sometimes “Fixed” mode is out of range and the radio doesn’t emit any spectrum data. You can also try un-checking and re-checking the “Enable WF” checkbox on the main “view” tab to see if that jogs it back to life.
Also, do you see “R8600” in the lower-right corner?
The problem was the changing of the last digit, somehow by itself,
in the “Hostname” box in the program.
This number should/must agree with what is in the radio.
This has happened to me before.
No idea why it changes.
Only has been the very last digit that changes (in the program)
The last digit (octet) of the radio IP address will not change by itself in wfview. Most likely is that your radio is being allocated a different IP address by your router/DHCP server. There should be a method of setting this as a reserved address (within your router) so that your radio always receives the same address but the process is different for every make/model of router.
