Indeed appreciate;)
That is why I am supporting you with my python code that is working!
All works fine now with your latest commit!
Indeed appreciate;)
Thatās great!
I will probably tidy things up a bit but it is a good startā¦
One more thing but I will need to test it more.
I think that first press of F1 is not reacting at all. Only the second.
But will test it more and report.
Thanks again!
I have discovered a potential cause for this, if pressing F1 is the first thing you do after starting wfview, it is possible that would get lost.
I have pushed a fix which may (or may not) fix this issue.
So.
LEDs are now working perfectly.
TRANSMIT button alsoā¦
But if I set Band+/Band- or Mode+/Mode- or Band20 and Band17 or Split On Split Off for F-1/F-2 buttons it doesnāt work.
The only function that worked was PTT On/Off/Toggleā¦
wfview detects button press and even is doing something but it doesnt work:
2023-02-02 20:39:16.252 DBG usbcontrol: F-2 key down
2023-02-02 20:39:16.252 INF usbcontrol: On Button event: ā17mā
2023-02-02 20:39:16.253 DBG usbcontrol: write() success
2023-02-02 20:39:16.531 DBG usbcontrol: PTT key down
2023-02-02 20:39:16.531 INF usbcontrol: On Button event: āPTT Onā
2023-02-02 20:39:16.532 DBG usbcontrol: write() success
2023-02-02 20:39:16.532 DBG usbcontrol: F-2 key up
2023-02-02 20:39:16.532 INF usbcontrol: Off Button event: āNoneā
2023-02-02 20:39:16.533 DBG usbcontrol: write() success
2023-02-02 20:39:16.735 DBG usbcontrol: PTT key up
2023-02-02 20:39:16.735 INF usbcontrol: Off Button event: āPTT Offā
2023-02-02 20:39:16.736 DBG usbcontrol: write() success
2023-02-02 20:39:17.920 DBG usbcontrol: F-2 key down
2023-02-02 20:39:17.920 INF usbcontrol: On Button event: ā17mā
2023-02-02 20:39:17.921 DBG usbcontrol: write() success
2023-02-02 20:39:18.173 DBG usbcontrol: F-2 key up
2023-02-02 20:39:18.173 INF usbcontrol: Off Button event: āNoneā
2023-02-02 20:39:18.174 DBG usbcontrol: write() success
2023-02-02 20:39:18.653 DBG usbcontrol: F-1 key down
2023-02-02 20:39:18.653 INF usbcontrol: On Button event: ā20mā
2023-02-02 20:39:18.654 DBG usbcontrol: write() success
2023-02-02 20:39:18.906 DBG usbcontrol: F-1 key up
2023-02-02 20:39:18.906 INF usbcontrol: Off Button event: āNoneā
2023-02-02 20:39:18.907 DBG usbcontrol: write() success
I havenāt tested all functions but this is what Iāve found.
@phil Iāve just ordered Express Shuttle so will be able to make compression tests in next days;)
The Split buttons arenāt currently implemented, but the band buttons should work. You probably need to press the reset commands button to get the latest updates though.
Ok reset helped, but then while jumping through the band (on IC-7610):
Ah, ok it expected to show we are out of range of Edges? Koz that RED MESSAGE looks scary;)
Thatās the point. Itās to stop people wondering where the VFO indicator is!
Point taken;)
Good so I can confirm that all works now completely on RC-28;)
Iām also hoping to later implement a function that checks one of your pre-defined edges to see if there is one that contains the selected frequency. I mean, why not? Clearly the intent is to use the scope!
for this āissueā I defined edge 4 to have a certain width and use fix scrollmode.
depending on mode, I vary the width for cw and ssb, in contests. else 500 kHz to1 MHz is good. never out of range!
I just connected ShuttleXpressā¦ and have a comparisonā¦
One thing to note for SSB/CW example:
Knob on the radio - one rotation is ~6kHz
ShuttleXpress - one rotation is 1kHz frequency change on default settings of 100Hz step.
RC-28 - one rotation is ~56kHz
Maybe we should change the default step when RC-28 is connected to 10Hz?
Or reduce the number of counts/10?
How do you think @phil ?
I donāt understand this discussion. I am seeing the OUT OF RANGE red button flashing, the WF display shows nothing and it used to work with V1.59 on x86 mode (on my Windows 10 and 11 64 bit machines). I donāt know what the Edges settings are supposed to be for and have never used them
Thatās the way it was always set and the problem is always there
You need to provide more details then, like screenshot at leastā¦
As with āCenterā there should be no OUT OF RANGEā¦ as there is no range but Spanā¦
That is very strange, hopefully @eliggett can weigh-in as he wrote that bit, what happens if you try the other Spectrum modes?
Gordon,
What radio are you using and what firmware version does it have installed?
