I tried to run Wfview using
Currently not sure how to use the microphone, but I can operate receive.
winlato supports ALSA and PulesAudio.
Installation procedure
1.Download and install Winlator_7.1.apk.
2.Download the Wfview installer.
3.Install Wfview on Windows created by Winlator.
It may not be able to install. In that case, try on another phone.
4.Start Wfview.
You can change the settings for each shortcut, so you can easily change the resolution and other settings to suit your needs.
The screen is set to 960X544.
