Hey all, in installing wfview I encountered this, is there something you might recommend to allow futher progress in my download?
Max KK7HI
qmake: could not find a Qt installation of ‘’
Max KK7HI
Hi Max.
What method did you use to install wfview as there are lots of pre-requisite components?
It is also possible that you have conflicting versions of Qt installed? You could try:
qtchooser -list-versions
If you have multiple versions, use the following to select Qt5:
qtchooser -qt=qt5
Hi Phil, thanks for responding, I resolved the issue by downloading the qmake (default) file. refired it, it was happy and finished the install.
