I can see virtual com ports (dev/cu.usbmodem1411201) in WSJTX but not in WFVIEW. I am running Mac OS 11.3.1
Thoughts or help
Mike KD9RKQ
Thoughts or help
Mike KD9RKQ
Hi Mike,
You’ll need to connect to the radio using wfview first. Then tell wfview that you want to run a virtual serial port from wfview. This is where you can see how the virtual port is defined (see the Settings tab). Then tell WSJT-X that you want to use the virtual port created in wfview.
Does that make sense?
thanks,
