TS-890 -- Needs a Receive Audio MUTE button
I use the TS-890 for some HF nets on 40m. Those nets require I switch between my radio and different HF SDRs to hear everyone. I route all the audio through the PC and then just “mute” the receiver that is not in use. Right now in WFVIEW, I have to use the audio slider and slide all the way down and back up again. Maybe you could come up with a way to mute the audio. I was thinking that you could make the circle on the slider a clickable mute button. I am able to mute my audio in the Open890 software that is now unsupported.
This is something we can look at.
Thanks Phil. I’m happy to debug anything you want to try.
