I’m connected via LAN. Everything works except transmit audio.
Do I have to choose between LAN and MIC/whatever on the radio? It would be annoying to leave it in LAN all the time and switch back to MIC every time I want to use it locally, and I’m hoping there’s a way around it without having to run the server on the home computer just for this…
Is there a way to return settings to previous when exiting, or do I have to keep toggling audio manually from LAN to M/U every time before I disconnect the radio? I suppose I could create a “reset” configuration shortcut to run the program again after exiting that would reset the radio to a preset original configuration.
Edit: I just tried that, and it doesn’t seem to save those changes to the individual .conf files. It just stays on where I set it last. The two I have to keep changing are LAN to M/U and the power level.
