assuming you also have the 705 next to you – select the audio scope and you can check if it picks up audio from your computer mike, the handike. These should not be picked up.
Also the tune button iirc will send out a continuous tone which should give you a nice sine wave on the audio scope. Finally you could select the monitor option and listen of the sound from wsjtx gets into your rig.
