I used the build script below and an receive the error about usb. The build script was freshly downloaded
Ubuntu:~/Downloads$ ./fullbuild-wfview.sh creator-widgets
The tail end of the log is below:
…/wfview/usbcontroller.cpp: In member function ‘void usbController::runTimer()’:
…/wfview/usbcontroller.cpp:649:35: warning: ISO C++ says that these are ambiguous, even though the worst conversion for the first is better than the worst conversion for the second:
649 | if (data[9] < 0x07) {
In file included from /usr/include/x86_64-linux-gnu/qt5/QtCore/qstring.h:50,
from /usr/include/x86_64-linux-gnu/qt5/QtCore/qcoreapplication.h:44,
from /usr/include/x86_64-linux-gnu/qt5/QtCore/QCoreApplication:1,
from …/wfview/cachingqueue.h:3,
from …/wfview/usbcontroller.h:4,
from …/wfview/usbcontroller.cpp:2:
/usr/include/x86_64-linux-gnu/qt5/QtCore/qbytearray.h:620:17: note: candidate 1: ‘bool QByteRef::operator<(char) const’
620 | inline bool operator<(char c) const
…/wfview/usbcontroller.cpp:649:35: note: candidate 2: ‘operator<(int, int)’ (built-in)
…/wfview/usbcontroller.cpp:651:43: warning: ISO C++ says that these are ambiguous, even though the worst conversion for the first is better than the worst conversion for the second:
651 | } else if (data[9] == 0x25) {
/usr/include/x86_64-linux-gnu/qt5/QtCore/qbytearray.h:612:17: note: candidate 1: ‘bool QByteRef::operator==(char) const’
612 | inline bool operator==(char c) const
…/wfview/usbcontroller.cpp:651:43: note: candidate 2: ‘operator==(int, int)’ (built-in)
…/wfview/usbcontroller.cpp:653:43: warning: ISO C++ says that these are ambiguous, even though the worst conversion for the first is better than the worst conversion for the second:
653 | } else if (data[9] == 0x30) {
…/wfview/usbcontroller.cpp:653:43: note: candidate 2: ‘operator==(int, int)’ (built-in)
…/wfview/usbcontroller.cpp:655:43: warning: ISO C++ says that these are ambiguous, even though the worst conversion for the first is better than the worst conversion for the second:
655 | } else if (data[9] == 0x31) {
…/wfview/usbcontroller.cpp:655:43: note: candidate 2: ‘operator==(int, int)’ (built-in)
…/wfview/usbcontroller.cpp:657:43: warning: ISO C++ says that these are ambiguous, even though the worst conversion for the first is better than the worst conversion for the second:
657 | } else if (data[9] == 0x35) {
…/wfview/usbcontroller.cpp:657:43: note: candidate 2: ‘operator==(int, int)’ (built-in)
…/wfview/usbcontroller.cpp:659:43: warning: ISO C++ says that these are ambiguous, even though the worst conversion for the first is better than the worst conversion for the second:
659 | } else if (data[9] == 0x33) {
…/wfview/usbcontroller.cpp:659:43: note: candidate 2: ‘operator==(int, int)’ (built-in)
…/wfview/usbcontroller.cpp:661:43: warning: ISO C++ says that these are ambiguous, even though the worst conversion for the first is better than the worst conversion for the second:
661 | } else if (data[9] == 0x34) {
…/wfview/usbcontroller.cpp:661:43: note: candidate 2: ‘operator==(int, int)’ (built-in)
…/wfview/usbcontroller.cpp:888:59: error: ambiguous overload for ‘operator=’ (operand types are ‘QString’ and ‘int’)
888 | dev->knobValues[i].name = 0;
In file included from /usr/include/x86_64-linux-gnu/qt5/QtCore/qcoreapplication.h:44,
/usr/include/x86_64-linux-gnu/qt5/QtCore/qstring.h:270:14: note: candidate: ‘QString& QString::operator=(QChar)’
270 | QString &operator=(QChar c);
/usr/include/x86_64-linux-gnu/qt5/QtCore/qstring.h:271:14: note: candidate: ‘QString& QString::operator=(const QString&)’
271 | QString &operator=(const QString &) noexcept;
/usr/include/x86_64-linux-gnu/qt5/QtCore/qstring.h:274:21: note: candidate: ‘QString& QString::operator=(QString&&)’
274 | inline QString &operator=(QString &&other) noexcept
/usr/include/x86_64-linux-gnu/qt5/QtCore/qstring.h:841:40: note: candidate: ‘QString& QString::operator=(const char*)’
841 | inline QT_ASCII_CAST_WARN QString &operator=(const char *ch)
/usr/include/x86_64-linux-gnu/qt5/QtCore/qstring.h:843:40: note: candidate: ‘QString& QString::operator=(const QByteArray&)’
843 | inline QT_ASCII_CAST_WARN QString &operator=(const QByteArray &a)
/usr/include/x86_64-linux-gnu/qt5/QtCore/qstring.h:845:40: note: candidate: ‘QString& QString::operator=(char)’
845 | inline QT_ASCII_CAST_WARN QString &operator=(char c)
…/wfview/usbcontroller.cpp: In member function ‘void usbController::receiveLevel(funcs, quint8)’:
…/wfview/usbcontroller.cpp:2116:40: warning: unused parameter ‘cmd’ [-Wunused-parameter]
2116 | void usbController::receiveLevel(funcs cmd, quint8 level)
…/wfview/usbcontroller.cpp:2116:52: warning: unused parameter ‘level’ [-Wunused-parameter]
g++ -c -pipe -s -fvisibility=hidden -fvisibility-inlines-hidden -faligned-new -O2 -std=gnu++1z -Wall -Wextra -D_REENTRANT -fPIC -DUSB_CONTROLLER -DWFVIEW_VERSION="1.94" -DBUILD_WFVIEW -D__LINUX_PULSE__ -DQT_DEPRECATED_WARNINGS -DQCUSTOMPLOT_USE_LIBRARY -DUSE_SSE -DUSE_SSE2 -DOUTSIDE_SPEEX -DRANDOM_PREFIX=wf -DEIGEN_MPL2_ONLY -DEIGEN_DONT_VECTORIZE -DEIGEN_VECTORIZE_SSE3 -DPREFIX="/usr/local" -DHOST="hostname
" -DUNAME="whoami
" -DGITSHORT="d1aeb04" -DQT_NO_DEBUG -DQT_MULTIMEDIA_LIB -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -DQT_GAMEPAD_LIB -DQT_GUI_LIB -DQT_SERIALPORT_LIB -DQT_WEBSOCKETS_LIB -DQT_NETWORK_LIB -DQT_XML_LIB -DQT_CORE_LIB -I…/wfview -I. -I…/wfview/resampler -I/usr/include/x86_64-linux-gnu/qt5 -I/usr/include/x86_64-linux-gnu/qt5/QtMultimedia -I/usr/include/x86_64-linux-gnu/qt5/QtPrintSupport -I/usr/include/x86_64-linux-gnu/qt5/QtWidgets -I/usr/include/x86_64-linux-gnu/qt5/QtGamepad -I/usr/include/x86_64-linux-gnu/qt5/QtGui -I/usr/include/x86_64-linux-gnu/qt5/QtSerialPort -I/usr/include/x86_64-linux-gnu/qt5/QtWebSockets -I/usr/include/x86_64-linux-gnu/qt5/QtNetwork -I/usr/include/x86_64-linux-gnu/qt5/QtXml -I/usr/include/x86_64-linux-gnu/qt5/QtCore -I. -I. -I/usr/lib/x86_64-linux-gnu/qt5/mkspecs/linux-g++ -o controllersetup.o …/wfview/controllersetup.cpp
make: *** [Makefile:1967: usbcontroller.o] Error 1
make: *** Waiting for unfinished jobs…
real 1m35.136s
user 2m51.090s
sys 0m15.746s
Error in make step.
wfview was not compiled.
