EDIT: Just noted the updated settings branch and will test that.
UPDATE 2:
Audio continues to stream but no CI-V. Stopped the client. Logfile on client:
2022-01-14 07:25:35.668 INF system: "wfview version: 1.2d (Git:b1ef680 on Dec 4 2021 at 16:26:19 by phil@Phils-MacBook-Pro-3.local)\nOperating System: macOS 12.1 (arm64)\nBuild Qt Version 5.15.2. Current Qt Version: 5.15.2\n"
2022-01-14 07:25:35.794 WRN qt.qpa.fonts: Populating font family aliases took 83 ms. Replace uses of missing font family "DejaVu Sans" with one that exists to avoid this cost.
2022-01-14 07:25:35.822 INF default: setState 1
2022-01-14 07:25:35.822 INF default: setState 0
2022-01-14 07:25:35.842 INF system: Loading settings from "/Users/ron/Library/Containers/org.wfview.wfview/Data/Library/Preferences/org.wfview.wfview.plist"
2022-01-14 07:25:35.843 INF rigctld: started on port 4533
2022-01-14 07:25:35.844 INF gui: Got Audio Output: "Multi-Output Device"
2022-01-14 07:25:35.844 INF gui: Got Audio Input: "MacBook Pro Microphone"
2022-01-14 07:25:35.844 INF default: Getting server config
2022-01-14 07:25:35.873 INF system: Cannot prepare WF view without rigCaps. Waiting on this.
2022-01-14 07:25:35.873 INF udp: Starting udpHandler user: "hampi" rx latency: 100 tx latency: 101 rx sample rate: 16000 rx codec: 1 tx sample rate: 16000 tx codec: 1
2022-01-14 07:25:35.875 INF serial: Opened pt device: 31 , attempting to grant pt status
2022-01-14 07:25:35.875 INF serial: Opened pseudoterminal, slave name : /dev/ttys000
2022-01-14 07:25:35.875 INF udp: UDP Stream bound to local port: 64861 remote port: 50001
2022-01-14 07:25:35.875 INF serial: Created link to "/dev/ttys000" from "/Users/ron/Library/Containers/org.wfview.wfview/Data/Downloads/rig-pty1"
2022-01-14 07:25:35.899 INF system: Received CommReady!!
2022-01-14 07:25:35.899 INF default: Setting rig state
2022-01-14 07:25:36.413 INF udp: udpHandler : Received I am here from: QHostAddress("::ffff:192.168.2.220")
2022-01-14 07:25:36.416 INF udp: udpHandler : Received I am ready
2022-01-14 07:25:36.416 INF udp: udpHandler : Sending login packet
2022-01-14 07:25:36.420 INF udp: Got connection type: "WFVIEW"
2022-01-14 07:25:36.420 INF udp: udpHandler : Received matching token response to our request
2022-01-14 07:25:36.420 INF udp: udpHandler : Detected connection speed WFVIEW
2022-01-14 07:25:36.424 INF udp: udpHandler Received radio capabilities, Name: "IC-7300" Audio: "ICOM_VAUDIO" CIV: 94
2022-01-14 07:25:36.425 INF default: Received serial port baud rate from remote server: 115200
2022-01-14 07:25:36.425 INF system: Delay command interval timing: 75 ms
2022-01-14 07:25:36.428 INF udp: Starting udpCivData
2022-01-14 07:25:36.429 INF udp: UDP Stream bound to local port: 50862 remote port: 50002
2022-01-14 07:25:36.429 INF udp: Starting udpAudio
2022-01-14 07:25:36.429 INF udp: UDP Stream bound to local port: 62035 remote port: 50003
2022-01-14 07:25:36.429 INF udp: udpHandler Got serial and audio request success, device name: "IC-7300"
2022-01-14 07:25:36.429 INF audio: Input Internal: sample rate 48000 channel count 2
2022-01-14 07:25:36.430 INF audio: Output setVolume: 255 ( 1 )
2022-01-14 07:25:36.430 INF audio: Input wf_resampler_init() returned: 0 resampleRatio: 0.333333
2022-01-14 07:25:36.430 INF audio: Output Internal: sample rate 48000 channel count 2
2022-01-14 07:25:36.430 INF audio: Input thread id 0x16de1b000
2022-01-14 07:25:36.430 INF audio: Output wf_resampler_init() returned: 0 resampleRatio: 3
2022-01-14 07:25:36.430 INF audio: Input start() running
2022-01-14 07:25:36.430 INF audio: Output thread id 0x16dd8f000
2022-01-14 07:25:36.430 INF audio: Output start() running
2022-01-14 07:25:36.480 INF audio: Input Audio now in idle state: 0 packets in buffer
2022-01-14 07:25:36.498 INF udp: udpAudio : Received I am here
2022-01-14 07:25:36.498 INF udp: udpCivData : Received I am here
2022-01-14 07:25:36.507 INF audio: Output Audio now in active state: 0 packets in buffer
2022-01-14 07:25:36.552 INF audio: Input Audio now in active state: 0 packets in buffer
2022-01-14 07:25:38.444 INF udp: CIV Watchdog: no CIV data received for 2s, requesting data start.
2022-01-14 07:25:40.699 INF audio: Output Audio now in stopped state: 0 packets in buffer
2022-01-14 07:25:40.760 INF udp: Closing UDP stream : "192.168.2.220" : 50003
2022-01-14 07:25:40.761 INF udp: Closing UDP stream : "192.168.2.220" : 50002
2022-01-14 07:25:40.761 INF udp: Sending token removal packet
2022-01-14 07:25:40.761 INF udp: Closing UDP stream : "192.168.2.220" : 50001
2022-01-14 07:25:40.762 INF udp: Starting udpHandler user: "hampi" rx latency: 100 tx latency: 101 rx sample rate: 16000 rx codec: 1 tx sample rate: 16000 tx codec: 1
2022-01-14 07:25:40.767 INF serial: Opened pt device: 23 , attempting to grant pt status
2022-01-14 07:25:40.768 INF serial: Opened pseudoterminal, slave name : /dev/ttys001
2022-01-14 07:25:40.768 INF serial: Created link to "/dev/ttys001" from "/Users/ron/Library/Containers/org.wfview.wfview/Data/Downloads/rig-pty1"
2022-01-14 07:25:40.768 INF system: Received CommReady!!
2022-01-14 07:25:40.769 INF udp: UDP Stream bound to local port: 54393 remote port: 50001
2022-01-14 07:25:40.769 INF default: Setting rig state
2022-01-14 07:25:41.307 INF udp: udpHandler : Received I am here from: QHostAddress("::ffff:192.168.2.220")
2022-01-14 07:25:41.310 INF udp: udpHandler : Received I am ready
2022-01-14 07:25:41.311 INF udp: udpHandler : Sending login packet
2022-01-14 07:25:41.314 INF udp: Got connection type: "WFVIEW"
2022-01-14 07:25:41.314 INF udp: udpHandler : Received matching token response to our request
2022-01-14 07:25:41.315 INF udp: udpHandler : Detected connection speed WFVIEW
2022-01-14 07:25:41.318 INF udp: udpHandler Received radio capabilities, Name: "IC-7300" Audio: "ICOM_VAUDIO" CIV: 94
2022-01-14 07:25:41.318 INF default: Received serial port baud rate from remote server: 115200
2022-01-14 07:25:41.318 INF system: Delay command interval timing: 75 ms
2022-01-14 07:25:41.323 INF udp: Starting udpCivData
2022-01-14 07:25:41.324 INF udp: UDP Stream bound to local port: 54394 remote port: 50002
2022-01-14 07:25:41.324 INF udp: Starting udpAudio
2022-01-14 07:25:41.326 INF udp: UDP Stream bound to local port: 52883 remote port: 50003
2022-01-14 07:25:41.326 INF audio: Output setVolume: 255 ( 1 )
2022-01-14 07:25:41.326 INF audio: Input Internal: sample rate 48000 channel count 2
2022-01-14 07:25:41.326 INF udp: udpHandler Got serial and audio request success, device name: "IC-7300"
2022-01-14 07:25:41.327 INF audio: Output Internal: sample rate 48000 channel count 2
2022-01-14 07:25:41.327 INF audio: Input wf_resampler_init() returned: 0 resampleRatio: 0.333333
2022-01-14 07:25:41.327 INF audio: Output wf_resampler_init() returned: 0 resampleRatio: 3
2022-01-14 07:25:41.327 INF audio: Input thread id 0x16dc77000
2022-01-14 07:25:41.327 INF audio: Output thread id 0x16d55b000
2022-01-14 07:25:41.327 INF audio: Input start() running
2022-01-14 07:25:41.327 INF audio: Output start() running
2022-01-14 07:25:41.330 INF udp: udpCivData : Received I am here
2022-01-14 07:25:41.332 INF audio: Input Audio now in idle state: 0 packets in buffer
2022-01-14 07:25:41.333 INF udp: udpAudio : Received I am here
2022-01-14 07:25:41.360 INF audio: Output Audio now in active state: 0 packets in buffer
2022-01-14 07:25:41.419 INF audio: Input Audio now in active state: 0 packets in buffer
2022-01-14 07:25:43.424 INF udp: CIV Watchdog: no CIV data received for 2s, requesting data start.
2022-01-14 07:25:54.364 INF audio: Output Audio now in stopped state: 0 packets in buffer
2022-01-14 07:25:54.438 INF udp: Closing UDP stream : "192.168.2.220" : 50003
2022-01-14 07:25:54.439 INF udp: Closing UDP stream : "192.168.2.220" : 50002
2022-01-14 07:25:54.439 INF udp: Sending token removal packet
2022-01-14 07:25:54.439 INF udp: Closing UDP stream : "192.168.2.220" : 50001
2022-01-14 07:25:54.440 INF udp: Starting udpHandler user: "hampi" rx latency: 100 tx latency: 101 rx sample rate: 16000 rx codec: 1 tx sample rate: 16000 tx codec: 1
2022-01-14 07:25:54.447 INF serial: Opened pt device: 32 , attempting to grant pt status
2022-01-14 07:25:54.447 INF serial: Opened pseudoterminal, slave name : /dev/ttys004
2022-01-14 07:25:54.448 INF serial: Created link to "/dev/ttys004" from "/Users/ron/Library/Containers/org.wfview.wfview/Data/Downloads/rig-pty1"
2022-01-14 07:25:54.448 INF udp: UDP Stream bound to local port: 58592 remote port: 50001
2022-01-14 07:25:54.448 INF system: Received CommReady!!
2022-01-14 07:25:54.448 INF default: Setting rig state
2022-01-14 07:25:54.955 INF udp: udpHandler : Received I am here from: QHostAddress("::ffff:192.168.2.220")
2022-01-14 07:25:54.956 INF udp: udpHandler : Received I am here
2022-01-14 07:25:54.959 INF udp: udpHandler : Received I am ready
2022-01-14 07:25:54.959 INF udp: udpHandler : Sending login packet
2022-01-14 07:25:54.962 INF udp: Got connection type: "WFVIEW"
2022-01-14 07:25:54.963 INF udp: udpHandler : Received matching token response to our request
2022-01-14 07:25:54.963 INF udp: udpHandler : Detected connection speed WFVIEW
2022-01-14 07:25:54.967 INF udp: udpHandler Received radio capabilities, Name: "IC-7300" Audio: "ICOM_VAUDIO" CIV: 94
2022-01-14 07:25:54.967 INF default: Received serial port baud rate from remote server: 115200
2022-01-14 07:25:54.967 INF system: Delay command interval timing: 75 ms
2022-01-14 07:25:54.970 INF udp: Starting udpCivData
2022-01-14 07:25:54.971 INF udp: UDP Stream bound to local port: 54559 remote port: 50002
2022-01-14 07:25:54.972 INF udp: Starting udpAudio
2022-01-14 07:25:54.972 INF udp: UDP Stream bound to local port: 59502 remote port: 50003
2022-01-14 07:25:54.972 INF audio: Input Internal: sample rate 48000 channel count 2
2022-01-14 07:25:54.973 INF udp: udpHandler Got serial and audio request success, device name: "IC-7300"
2022-01-14 07:25:54.973 INF audio: Output setVolume: 255 ( 1 )
2022-01-14 07:25:54.973 INF audio: Input wf_resampler_init() returned: 0 resampleRatio: 0.333333
2022-01-14 07:25:54.973 INF audio: Output Internal: sample rate 48000 channel count 2
2022-01-14 07:25:54.973 INF audio: Input thread id 0x16dc77000
2022-01-14 07:25:54.973 INF audio: Output wf_resampler_init() returned: 0 resampleRatio: 3
2022-01-14 07:25:54.973 INF audio: Input start() running
2022-01-14 07:25:54.973 INF audio: Output thread id 0x16dbeb000
2022-01-14 07:25:54.973 INF audio: Output start() running
2022-01-14 07:25:54.980 INF udp: udpCivData : Received I am here
2022-01-14 07:25:54.980 INF audio: Input Audio now in idle state: 0 packets in buffer
2022-01-14 07:25:54.981 INF udp: udpAudio : Received I am here
2022-01-14 07:25:55.006 INF audio: Output Audio now in active state: 0 packets in buffer
2022-01-14 07:25:55.065 INF audio: Input Audio now in active state: 0 packets in buffer
2022-01-14 07:25:57.443 INF udp: CIV Watchdog: no CIV data received for 2s, requesting data start.
2022-01-14 07:26:04.993 INF rigctld: session connected: 46
2022-01-14 07:26:15.063 INF rigctld: 46 disconnected
2022-01-14 07:26:15.063 INF rigctld: session connected: 7
2022-01-14 07:26:15.131 INF rigctld: 7 disconnected
2022-01-14 07:26:15.132 INF rigctld: session connected: 7
2022-01-14 07:26:25.203 INF rigctld: 7 disconnected
2022-01-14 07:27:13.177 INF audio: Output Audio now in stopped state: 0 packets in buffer
2022-01-14 07:27:13.237 INF udp: Closing UDP stream : "192.168.2.220" : 50003
2022-01-14 07:27:13.238 INF udp: Closing UDP stream : "192.168.2.220" : 50002
2022-01-14 07:27:13.239 INF udp: Sending token removal packet
2022-01-14 07:27:13.239 INF udp: Closing UDP stream : "192.168.2.220" : 50001
2022-01-14 07:27:13.240 INF rigctld: closing rigctld
Worked again for a while after restart of the client. After about 25 minutes the audio and rig control stopped working. This time restart of the client didn’t fix it. Log file of client before restart:
2022-01-14 07:31:36.968 INF system: "wfview version: 1.2d (Git:b1ef680 on Dec 4 2021 at 16:26:19 by phil@Phils-MacBook-Pro-3.local)\nOperating System: macOS 12.1 (arm64)\nBuild Qt Version 5.15.2. Current Qt Version: 5.15.2\n"
2022-01-14 07:31:37.111 WRN qt.qpa.fonts: Populating font family aliases took 85 ms. Replace uses of missing font family "DejaVu Sans" with one that exists to avoid this cost.
2022-01-14 07:31:37.140 INF default: setState 1
2022-01-14 07:31:37.140 INF default: setState 0
2022-01-14 07:31:37.159 INF system: Loading settings from "/Users/ron/Library/Containers/org.wfview.wfview/Data/Library/Preferences/org.wfview.wfview.plist"
2022-01-14 07:31:37.162 INF rigctld: started on port 4533
2022-01-14 07:31:37.162 INF gui: Got Audio Output: "Multi-Output Device"
2022-01-14 07:31:37.162 INF gui: Got Audio Input: "MacBook Pro Microphone"
2022-01-14 07:31:37.163 INF default: Getting server config
2022-01-14 07:31:37.197 INF system: Cannot prepare WF view without rigCaps. Waiting on this.
2022-01-14 07:31:37.197 INF udp: Starting udpHandler user: "hampi" rx latency: 100 tx latency: 101 rx sample rate: 16000 rx codec: 1 tx sample rate: 16000 tx codec: 1
2022-01-14 07:31:37.369 INF serial: Opened pt device: 29 , attempting to grant pt status
2022-01-14 07:31:37.369 INF serial: Opened pseudoterminal, slave name : /dev/ttys000
2022-01-14 07:31:37.369 INF serial: Created link to "/dev/ttys000" from "/Users/ron/Library/Containers/org.wfview.wfview/Data/Downloads/rig-pty1"
2022-01-14 07:31:37.369 INF system: Received CommReady!!
2022-01-14 07:31:37.370 INF default: Setting rig state
2022-01-14 07:31:37.370 INF udp: UDP Stream bound to local port: 63962 remote port: 50001
2022-01-14 07:31:37.899 INF udp: udpHandler : Received I am here from: QHostAddress("::ffff:192.168.2.220")
2022-01-14 07:31:37.900 INF udp: udpHandler : Received I am here
2022-01-14 07:31:37.902 INF udp: udpHandler : Received I am ready
2022-01-14 07:31:37.902 INF udp: udpHandler : Sending login packet
2022-01-14 07:31:37.906 INF udp: Got connection type: "WFVIEW"
2022-01-14 07:31:37.906 INF udp: udpHandler : Received matching token response to our request
2022-01-14 07:31:37.906 INF udp: udpHandler : Detected connection speed WFVIEW
2022-01-14 07:31:37.910 INF udp: udpHandler Received radio capabilities, Name: "IC-7300" Audio: "ICOM_VAUDIO" CIV: 94
2022-01-14 07:31:37.910 INF default: Received serial port baud rate from remote server: 115200
2022-01-14 07:31:37.910 INF system: Delay command interval timing: 75 ms
2022-01-14 07:31:37.915 INF udp: Starting udpCivData
2022-01-14 07:31:37.915 INF udp: UDP Stream bound to local port: 58576 remote port: 50002
2022-01-14 07:31:37.915 INF udp: Starting udpAudio
2022-01-14 07:31:37.916 INF udp: UDP Stream bound to local port: 52947 remote port: 50003
2022-01-14 07:31:37.916 INF audio: Input Internal: sample rate 48000 channel count 2
2022-01-14 07:31:37.916 INF audio: Output setVolume: 255 ( 1 )
2022-01-14 07:31:37.916 INF udp: udpHandler Got serial and audio request success, device name: "IC-7300"
2022-01-14 07:31:37.916 INF audio: Output Internal: sample rate 48000 channel count 2
2022-01-14 07:31:37.916 INF audio: Input wf_resampler_init() returned: 0 resampleRatio: 0.333333
2022-01-14 07:31:37.916 INF audio: Output wf_resampler_init() returned: 0 resampleRatio: 3
2022-01-14 07:31:37.916 INF audio: Input thread id 0x16b9e7000
2022-01-14 07:31:37.917 INF audio: Output thread id 0x16b95b000
2022-01-14 07:31:37.917 INF audio: Input start() running
2022-01-14 07:31:37.917 INF audio: Output start() running
2022-01-14 07:31:37.921 INF udp: udpCivData : Received I am here
2022-01-14 07:31:37.921 INF udp: udpAudio : Received I am here
2022-01-14 07:31:37.939 INF rig: Warning: Spectrum sequence max was zero, yet spectrum was received.
2022-01-14 07:31:37.960 INF rig: Warning: Spectrum sequence max was zero, yet spectrum was received.
2022-01-14 07:31:37.968 INF audio: Input Audio now in idle state: 0 packets in buffer
2022-01-14 07:31:37.982 INF rig: Warning: Spectrum sequence max was zero, yet spectrum was received.
2022-01-14 07:31:37.994 INF rig: Using incomingCIVAddr: (int): 148 hex: 94
2022-01-14 07:31:37.994 INF serial: Received rigCapabilities for "IC-7300"
2022-01-14 07:31:37.994 INF rig: Have rig ID: decimal: 148
2022-01-14 07:31:37.994 INF rigctld: Got rigcaps for: "IC-7300"
2022-01-14 07:31:37.995 INF audio: Output Audio now in active state: 0 packets in buffer
2022-01-14 07:31:37.995 INF system: Delay command interval timing: 25 ms
2022-01-14 07:31:38.039 INF audio: Input Audio now in active state: 0 packets in buffer
2022-01-14 07:31:39.776 INF rig: Received 0x15 center span data: for frequency 10000
2022-01-14 07:31:44.238 INF rigctld: session connected: 44
2022-01-14 07:31:50.267 INF audio: Output Audio now in active state: 0 packets in buffer
2022-01-14 07:44:42.911 INF udp: udpCivData : ******* seq number has rolled over ****** previous highest: ffff current: 1
2022-01-14 07:47:00.590 INF default: setState 3
2022-01-14 07:47:14.111 INF default: setState 0
2022-01-14 07:47:30.112 INF default: setState 3
2022-01-14 07:47:44.711 INF default: setState 0
2022-01-14 07:48:02.433 INF udp: CIV Watchdog: no CIV data received for 2s, requesting data start.
2022-01-14 07:48:02.433 INF udp: Audio Watchdog: no audio data received for 2s, restart required?
2022-01-14 07:57:52.029 INF audio: Output Audio now in stopped state: 0 packets in buffer
2022-01-14 07:57:52.097 INF udp: Closing UDP stream : "192.168.2.220" : 50003
2022-01-14 07:57:52.099 INF udp: Closing UDP stream : "192.168.2.220" : 50002
2022-01-14 07:57:52.099 INF udp: Sending token removal packet
2022-01-14 07:57:52.099 INF udp: Closing UDP stream : "192.168.2.220" : 50001
2022-01-14 07:57:52.101 INF rigctld: closing rigctld
This time, the wfview server was still showing a waterfall but the desktop became partly unresponsive. Wfview could not exit clean and was using 100% cpu (1 core). Log file of wfview server:
2022-01-14 07:31:02.348 INF system: "wfview version: 1.2d (Git:f8351ad on Jan 13 2022 at 14:19:02 by pi@hampi)\nOperating System: Raspbian GNU/Linux 10 (buster) (arm)\nBuild Qt Version 5.11.3. Current Qt Version: 5.11.3\n"
2022-01-14 07:31:02.667 INF default: setState 1
2022-01-14 07:31:02.669 INF default: setState 0
2022-01-14 07:31:02.670 INF default: setState 1
2022-01-14 07:31:05.739 INF system: Loading settings from "/home/pi/.config/wfview/wfview.conf"
2022-01-14 07:31:05.761 INF gui: Got Audio Output: ""
2022-01-14 07:31:05.761 INF gui: Got Audio Input: ""
2022-01-14 07:31:05.764 INF default: Getting server config
2022-01-14 07:31:06.097 INF system: Cannot prepare WF view without rigCaps. Waiting on this.
2022-01-14 07:31:06.097 INF udp.server: Starting udp server
2022-01-14 07:31:06.100 INF system: Could not find Icom serial port. Falling back to OS default. Use --port to specify, or modify preferences.
2022-01-14 07:31:06.108 INF udp.server: My IP Address: "0.0.0.0" My MAC Address: "E4:5F:01:1D:A2:39"
2022-01-14 07:31:06.108 INF udp.server: Server Binding Control to: 50001
2022-01-14 07:31:06.111 INF udp.server: Server Binding CIV to: 50002
2022-01-14 07:31:06.111 INF udp.server: Server Binding Audio to: 50003
2022-01-14 07:31:06.111 INF serial: Opened port: "/dev/ttyUSB0"
2022-01-14 07:31:06.429 INF system: Received CommReady!!
2022-01-14 07:31:06.430 INF system: Delay command interval timing: 75 ms
2022-01-14 07:31:06.431 INF default: Setting rig state for wfmain
2022-01-14 07:31:06.433 INF rig: Using incomingCIVAddr: (int): 148 hex: 94
2022-01-14 07:31:06.433 INF serial: Received rigCapabilities for "IC-7300"
2022-01-14 07:31:06.433 INF rig: Have rig ID: decimal: 148
2022-01-14 07:31:06.456 INF system: Delay command interval timing: 25 ms
2022-01-14 07:31:08.088 INF rig: Received 0x15 center span data: for frequency 10000
2022-01-14 07:31:37.901 INF udp.server: "::ffff:192.168.2.100" : New Control connection created
2022-01-14 07:31:37.901 INF udp.server: "::ffff:192.168.2.100" ( "Control" ): Received 'are you there'
2022-01-14 07:31:37.904 INF udp.server: "::ffff:192.168.2.100" ( "Control" ): Received 'Are you ready'
2022-01-14 07:31:37.907 INF udp.server: "::ffff:192.168.2.100" : Received 'login'
2022-01-14 07:31:37.908 INF udp.server: "::ffff:192.168.2.100" : User "hampi" login OK
2022-01-14 07:31:37.908 INF udp.server: "::ffff:192.168.2.100" ( "Control" ): Sending Login response: 1
2022-01-14 07:31:37.911 INF udp.server: "::ffff:192.168.2.100" : Received create token request
2022-01-14 07:31:37.911 INF udp.server: "::ffff:192.168.2.100" ( "Control" ): Sending Capabilities : 2
2022-01-14 07:31:37.912 INF udp.server: "::ffff:192.168.2.100" ( "Control" ): Client will have TX audio
2022-01-14 07:31:37.912 INF udp.server: "::ffff:192.168.2.100" ( "Control" ): Sending ConnectionInfo : 3
2022-01-14 07:31:37.916 INF udp.server: "::ffff:192.168.2.100" : Received request for radio connection
2022-01-14 07:31:37.916 INF udp.server: "::ffff:192.168.2.100" ( "Control" ): Sending Status
2022-01-14 07:31:37.916 INF udp.server: "::ffff:192.168.2.100" ( "Control" ): Sending ConnectionInfo : 5
2022-01-14 07:31:37.916 INF udp.server: "::ffff:192.168.2.100" : rxCodec: 1 txCodec: 1 rxSampleRate 16000 txSampleRate 16000 txBufferLen 101
2022-01-14 07:31:37.917 INF audio: Output setVolume: 255 ( 1 )
2022-01-14 07:31:37.917 INF audio: Output Internal: sample rate 48000 channel count 2
2022-01-14 07:31:37.917 INF audio: Input Internal: sample rate 48000 channel count 2
2022-01-14 07:31:37.917 INF audio: Output wf_resampler_init() returned: 0 resampleRatio: 3
2022-01-14 07:31:37.917 INF audio: Input wf_resampler_init() returned: 0 resampleRatio: 0.333333
2022-01-14 07:31:37.917 INF audio: Input thread id 0x94589380
2022-01-14 07:31:37.917 INF audio: Output thread id 0x94d8a380
2022-01-14 07:31:37.923 INF udp.server: "::ffff:192.168.2.100" ( "CIV" ): New connection created
2022-01-14 07:31:37.923 INF udp.server: "::ffff:192.168.2.100" ( "CIV" ): Received 'are you there'
2022-01-14 07:31:37.923 INF udp.server: "::ffff:192.168.2.100" ( "Audio" ): New connection created
2022-01-14 07:31:37.923 INF udp.server: "::ffff:192.168.2.100" ( "Audio" ): Received 'are you there'
2022-01-14 07:31:37.926 INF udp.server: "::ffff:192.168.2.100" ( "CIV" ): Received 'Are you ready'
2022-01-14 07:31:37.927 INF udp.server: "::ffff:192.168.2.100" ( "Audio" ): Received 'Are you ready'
2022-01-14 07:31:37.929 INF audio: Output Audio now in active state: 0 packets in buffer
2022-01-14 07:31:37.929 INF audio: Input Audio now in active state: 0 packets in buffer
2022-01-14 07:31:37.996 INF rig: Have rig ID: decimal: 148
2022-01-14 07:31:39.779 INF rig: Received 0x15 center span data: for frequency 10000
2022-01-14 07:32:37.447 INF udp.server: "::ffff:192.168.2.100" : Received token request
2022-01-14 07:32:37.447 INF udp.server: "::ffff:192.168.2.100" ( "Control" ): Sending Token response for type: 5
2022-01-14 07:33:37.447 INF udp.server: "::ffff:192.168.2.100" : Received token request
2022-01-14 07:33:37.447 INF udp.server: "::ffff:192.168.2.100" ( "Control" ): Sending Token response for type: 5
2022-01-14 07:34:37.448 INF udp.server: "::ffff:192.168.2.100" : Received token request
2022-01-14 07:34:37.449 INF udp.server: "::ffff:192.168.2.100" ( "Control" ): Sending Token response for type: 5
2022-01-14 07:35:37.447 INF udp.server: "::ffff:192.168.2.100" : Received token request
2022-01-14 07:35:37.447 INF udp.server: "::ffff:192.168.2.100" ( "Control" ): Sending Token response for type: 5
2022-01-14 07:36:37.448 INF udp.server: "::ffff:192.168.2.100" : Received token request
2022-01-14 07:36:37.448 INF udp.server: "::ffff:192.168.2.100" ( "Control" ): Sending Token response for type: 5
2022-01-14 07:37:37.447 INF udp.server: "::ffff:192.168.2.100" : Received token request
2022-01-14 07:37:37.447 INF udp.server: "::ffff:192.168.2.100" ( "Control" ): Sending Token response for type: 5
2022-01-14 07:38:37.445 INF udp.server: "::ffff:192.168.2.100" : Received token request
2022-01-14 07:38:37.446 INF udp.server: "::ffff:192.168.2.100" ( "Control" ): Sending Token response for type: 5
2022-01-14 07:39:37.443 INF udp.server: "::ffff:192.168.2.100" : Received token request
2022-01-14 07:39:37.444 INF udp.server: "::ffff:192.168.2.100" ( "Control" ): Sending Token response for type: 5
2022-01-14 07:40:24.756 INF udp.server: "::ffff:192.168.2.100" ( "CIV" ): Received 'retransmit' request for 43939
2022-01-14 07:40:24.756 INF udp.server: "::ffff:192.168.2.100" ( "CIV" ): Sending retransmit of aba3
2022-01-14 07:40:37.443 INF udp.server: "::ffff:192.168.2.100" : Received token request
2022-01-14 07:40:37.443 INF udp.server: "::ffff:192.168.2.100" ( "Control" ): Sending Token response for type: 5
2022-01-14 07:41:37.442 INF udp.server: "::ffff:192.168.2.100" : Received token request
2022-01-14 07:41:37.442 INF udp.server: "::ffff:192.168.2.100" ( "Control" ): Sending Token response for type: 5
2022-01-14 07:42:37.443 INF udp.server: "::ffff:192.168.2.100" : Received token request
2022-01-14 07:42:37.443 INF udp.server: "::ffff:192.168.2.100" ( "Control" ): Sending Token response for type: 5
2022-01-14 07:43:37.441 INF udp.server: "::ffff:192.168.2.100" : Received token request
2022-01-14 07:43:37.441 INF udp.server: "::ffff:192.168.2.100" ( "Control" ): Sending Token response for type: 5
2022-01-14 07:44:37.442 INF udp.server: "::ffff:192.168.2.100" : Received token request
2022-01-14 07:44:37.442 INF udp.server: "::ffff:192.168.2.100" ( "Control" ): Sending Token response for type: 5
2022-01-14 07:45:37.441 INF udp.server: "::ffff:192.168.2.100" : Received token request
2022-01-14 07:45:37.441 INF udp.server: "::ffff:192.168.2.100" ( "Control" ): Sending Token response for type: 5
2022-01-14 07:46:37.441 INF udp.server: "::ffff:192.168.2.100" : Received token request
2022-01-14 07:46:37.442 INF udp.server: "::ffff:192.168.2.100" ( "Control" ): Sending Token response for type: 5
2022-01-14 07:47:00.593 INF default: setState 3
2022-01-14 07:47:14.114 INF default: setState 0
2022-01-14 07:47:30.114 INF default: setState 3
2022-01-14 07:47:37.439 INF udp.server: "::ffff:192.168.2.100" : Received token request
2022-01-14 07:47:37.439 INF udp.server: "::ffff:192.168.2.100" ( "Control" ): Sending Token response for type: 5
2022-01-14 07:47:44.713 INF default: setState 0
2022-01-14 07:48:00.988 INF default: setState 3
2022-01-14 07:51:00.288 INF default: setState 0
2022-01-14 08:05:18.347 INF udp.server: Closing udpServer
2022-01-14 08:05:18.347 INF udp.server: Deleting "Control" connection to: "::ffff:192.168.2.100" : "63962"
2022-01-14 08:05:18.351 INF udp.server: Found "Control" connection to: "::ffff:192.168.2.100" : "63962"
2022-01-14 08:05:18.351 INF udp.server: Current Number of clients connected: 0
2022-01-14 08:05:18.352 INF audio: Input Audio now in stopped state: 0 packets in buffer
2022-01-14 08:05:18.352 INF audio: Output Audio now in stopped state: 0 packets in buffer
2022-01-14 08:05:18.353 INF udp.server: Deleting "CIV" connection to: "::ffff:192.168.2.100" : "58576"
2022-01-14 08:05:18.392 INF udp.server: Found "CIV" connection to: "::ffff:192.168.2.100" : "58576"
2022-01-14 08:05:18.395 INF udp.server: Current Number of clients connected: 0
2022-01-14 08:05:18.399 INF udp.server: Deleting "Audio" connection to: "::ffff:192.168.2.100" : "52947"
2022-01-14 08:05:18.448 INF udp.server: Found "Audio" connection to: "::ffff:192.168.2.100" : "52947"
2022-01-14 08:05:18.453 INF udp.server: Current Number of clients connected: 0
Hope this helps Phil.
/Ron - 73 de PA7CT
