Hi all,
I’ve read through a number of threads and tried all the suggestions, but I can’t get wfview to connect to either my IC-7300 or my IC-9700. Both are connected to my PC, running Windows 10, using USB cables.
I opened the wfview.log and it said this;
2022-01-06 18:39:16.092 INF system: “Starting wfview: build ea09647 on Jul 26 2021 at 11:23:33 by build@wfview.org”
2022-01-06 18:39:16.092 INF system: “Operating System: Windows 10 Version 2009 (i386)”
2022-01-06 18:39:16.092 INF system: “Build Qt Version 5.15.2. Current Qt Version: 5.15.2”
2022-01-06 18:39:16.500 INF default: setState 1
2022-01-06 18:39:16.500 INF default: setState 0
2022-01-06 18:39:16.778 INF system: Loading settings from “\HKEY_CURRENT_USER\Software\wfview\wfview”
2022-01-06 18:39:16.801 INF gui: Got Audio Output: “Speakers (4- USB Audio CODEC )”
2022-01-06 18:39:16.801 INF gui: Got Audio Input: “Microphone (4- USB Audio CODEC )”
2022-01-06 18:39:16.816 INF default: Getting server config
2022-01-06 18:39:16.932 INF system: Cannot prepare WF view without rigCaps. Waiting on this.
2022-01-06 18:39:16.932 INF udp.server: Starting udp server
2022-01-06 18:39:16.932 INF system: Could not find Icom serial port. Falling back to OS default. Use --port to specify, or modify preferences.
2022-01-06 18:39:16.932 INF serial: Could not open serial port “COM1” , please restart.
2022-01-06 18:39:16.948 INF udp.server: My IP Address: “192.168.0.6” My MAC Address: “C0:4A:00:14:73:0B”
2022-01-06 18:39:16.948 INF udp.server: Server Binding Control to: 50001
2022-01-06 18:39:16.948 INF udp.server: Server Binding CIV to: 50002
2022-01-06 18:39:16.948 INF system: Received CommReady!!
2022-01-06 18:39:16.948 INF system: Delay command interval timing: 75 ms
2022-01-06 18:39:16.948 WRN default: QIODevice::write (QSerialPort): device not open
2022-01-06 18:39:16.948 INF udp.server: Server Binding Audio to: 50003
2022-01-06 18:39:17.017 WRN default: QIODevice::write (QSerialPort): device not open
Then a long string of “device not open” lines.
the “COM1” thing confuses me as the ports that the IC-9700 and IC-7300 use are COM9, COM10 and COM11 respectively. I have tried specifying a COM port in the set up, but with no sucess.
I’ve closed all other programs that might use the COM ports, such as WSJT-X, and have rebooted the PC and unplugged and replugged the USB cables.
I have got CI-V Transceive set to “ON” for both radios, and I keep checking that it’s on. I’ve switched off the IC-9700 and tried connecting to the IC-7300, and vice versa.
Any ideas as to what I’m doing wrong please?
Thanks - Dave (G0DJA)
