Hi
While using WFview server I am seeing the following logging:
Unknown meter level (0x15) received at register 7 with level 163
Radio is IC7300 connected USB
Any ideas how to resolve
Hi
Possibly your client wfview is requesting data that the server doesn’t understand, but, that the radio does understand. And the reply isn’t understood by the server.
It’s not a problem. But you could probably update both client and server to the same version (with updated rig files).
Are the meters working?
Hi
Whats the easist way to update the server. I am not sure the SWR meter is working. S and Volts are
Updating the server won’t change anything about the metering on the client side.
Updating the server might remove some of the warnings you see on the server side log. Or it might not.
