what usb headset do you like REmote over the internet?
jimmy ka3vgm
I use Jabra 65 and or any decent usb audio. Tried also direct headset 3.5mm jack. Worked very well also. Jiri
Hi Jimmy,
I generally dont use a headset with mic and phones. I have one which has phones for rx though. I used to operate Phone when I was first licensed in 1960, nowadays CW , digi , SSTV and RTTY.
73 Alan VK7BO
I use a Phillips usb headset that was all of $20.00 on Amazon.
John
N0QJA
i can’t find a Phillips headset is it still on there? On Fri, 12 Apr
2024 12:40:00 +0000, you wrote:
there are different one
is it
https://www.amazon.com/Jabra-Wireless-Bluetooth-Headphones-Packaging/dp/B0728KWLZK/ref=sr_1_11?crid=1KBO5BAWJFV9H&dib=eyJ2IjoiMSJ9.vOyLc_DemtD14qVIv19htEPu7mrGPFTjfGeUq2JXNPNU6qqi6NJ78PqwBR01zYRvA_o284BVn4r-rir6kyBfBfVRbsRs8qnsIuOEulsYTzPSBpmzNiorQCYye_ioz2mRJaLY_CEWZgxF_u4mAcKFjwuQelktXOsRqOBtIrspFcQku6ykA9iIL-IAjoo_f21UsXmJZvX1SG4eaGrBCPnAW3us3JQIEPgh_QTXSkrUiDY.bQq3KRLyAehBe2_huEUB3_t7M5qpC-1A8ZfNWvOBHms&dib_tag=se&keywords=Jabra+65&qid=1712928909&sprefix=jabra+65+%2Caps%2C99&sr=8-11
if not do u have full model number ?
Most of what you find on Amazon is ching-chong garbage. A cost-effective headset a client uses for his call center is the Yealink UH37 (UC version, but it shouldn’t matter) sourced from Telecom Spot: https://www.thetelecomspot.com. You can kit it in mono or dual ear and it is good quality at the $60 price point.
thank you very much i will look into all of this
jimmy ka3vgm
