Ve6SCL
(Steve)
4 September 2026 23:09
1
I am trying to get a hid compliant usb keyboard to work when I enable the usb controllers and click setup usb controller it say no usb controller found and manual I know you only say certian controllers work. was hoping I might be able to get this one working
This is the keyboard
VAYDEER One-Handed Mechanical Keyboard with 9 Fully Programmable Keys, Support NKRO,Hotkeys,One-Click Start,Floating Window and Macro Multifunctional Keypad Compatible with iOS,Windows : Amazon.ca: Electronics
I am running windows 11 pro ICOM IC 7300MK2 I connect via lan or or over a wan
and I have check both FAQ
Operating System:
Method of download attempted (from wfview.org , package manager, source code, etc):
Radio Make and Model:
Method of radio connectivity (USB, WiFi, Ethernet, etc):
Did you check the FAQ and read the manual ?
eliggett
(Elliott Liggett)
4 September 2026 23:29
2
Is your device listed on our USB Controllers part of the manual?
Ve6SCL
(Steve)
5 September 2026 00:56
3
Steven La Hay
PO 3784 117 4th st
Stirling AB T0K2E0
403-393-2980 Hams Over IP 101837
VE6SCL VA6SCL
eliggett
(Elliott Liggett)
5 September 2026 04:23
4
Sorry, I re-read your initial email.
If it’s not listed as supported, then we would need someone to send us a few and then we can test with it.
It’s probably a better value overall to just fine one that is already supported.
Ve6SCL
(Steve)
5 September 2026 12:20
5
Steven La Hay
PO 3784 117 4th st
Stirling AB T0K2E0
VE6SCL VA6SCL
