sunnybeam
(Christophe)
20 September 2021 19:33
1
What a wonderful program! I can control my both transceivers the 9700 and 705 with Wfview. It would also be nice that you can switch between mem and vfo. And you can also use a Dellking H3 bluetooth microphone. These are just suggestions, thanks for the hard work you’ve already done !
73 de on5cdg
roeland
(Roeland Jansen)
21 September 2021 10:21
2
Christophe,
memory is something that’s going to be addressed in the future.
Regarding sound systems: so far all OS supported systems should be
useable.
sunnybeam
(Christophe)
21 September 2021 18:11
3
You can choose the mike for audio output but you can’t use the mike’s PTT button. This is the mike I mean :
phil
(Phil Taylor M0VSE)
21 September 2021 18:31
4
Thanks Christophe.
I will need to do some more research on this as I wasn’t aware that this existed, it should be possible to add support for this within wfview.
sunnybeam
(Christophe)
2 January 2022 22:17
5
Hi Phil,
That would be fantastic if this is possible. Then you can use a mini PC in the car connected via 4G GSM network. And make qso with the bluetooth mike.
Christophe
