Using AutoTrack in Split operation causes offset to double or even triple on IC-7300
Radio Model: Icom 7300
Connectivity: USB
Operating System: Win 10x64
wfview version 1.6.4
Manual, FAQ, googled, all checked.
What I did:
  • Enter a TX frequency, for example 29.1 mhz on the dial.
  • Enter repeater setup.
  • Activate Split On
  • Select AutoTrack
  • Enter 100 khz
  • Select Split-
  • TX frequency box populates with 29.000 mhz
  • Split shows correctly on the radio as well, 29.1 and 29.0 mhz in the split.
  • I then mic key down on the radio’s physical mic:
  • TX activates, but the frequency drops to 28.9 mhz.
  • Same behavior with “Transmit” button in WFview.
Expected behavior:
TX stays at indicated split frequency and the offset tracks as I move up and down the dial
Observed behavior:
At key down, the offset is applied to the split frequency, and the radio ends up transmitting at a freqency that’s double the offset. It seems that the offset is being applied twice, and in some cases, even three times. This behavior is also shown when doing a positive offset. Looks like the software is reading the TX frequency after it’s already transmitting, then applying the offset again, and then perhaps even applying it a third time. Rapidly keying the TX can even cause further issues with the AutoTrack feature.
Thank you.
the whole split repeater shift stuff is changed for v2.
so best to waitand see when it arrives.
