V2.23 or v2.22
  1. Operating System: W11
  2. Method of download attempted (from wfview.org, package manager, source code, etc): Wfvview.org
  3. Radio Make and Model: IC7610
  4. Method of radio connectivity (USB, WiFi, Ethernet, etc): USB/WIFI
  5. Did you check the FAQ and read the manual? YES
Hello
I have downloaded V2.23 apparently without any issue, but when I open Wfview it says v2.22 (please consider I was starting from 2.21).
What could be the issue?
thanks
IU0DHV, Peter
I have the same issue.
Did you ever have 2.22 installed?
No I did not. I was not aware of it and kept on running 2.21. Then today I discovered the 2.23 and downloaded it, but apparently it is the 2.22.
Can I do something to get the 2.23?
You probably have it and I messed up the version string.
Ok thanks. Once you check it and change it, please let us now so we can download it again and see the right label.
