Dear Elliott,
As of version 1.53 on the client, no proper audio adjustable. With me on the Windows PC, I can try whatever I want.
Everything up tzur version 1.52 is but ok!!!
Can you tell me there, are you still working on it???
Many greetings Jan-Peter - DL3KVT -
The error is that it cannot find the audio device that is saved in the preferences. We have seen that sometimes the different APIs cannot line up one audio device name with the device list. This can also happen if the audio device list changes while wfview is open or is different from the list when you last saved the settings.
Can you try disconnecting from the radio with the Disconnect button, re-selecting the audio device by first selecting a different device and then going back to the desired one, and then, Save Settings, and Connect?
You may also want to consider a USB headset which you only use for wfview; it might be easier, not sure.
