WATERFALL IC-R8600
hello to all and thank you to those who develop this great software .
who could explain me how to have the waterfall of my ic-R8600 on wfview impossible I have well down right IC-R8600 I can drive my post but no waterfall thank you for your help
F5PLS near PARIS
It should just work (it does on mine)
You need to either, connect via USB at 115,200 (make sure that CI-V unlink is selected in the radio and the radio CI-V baud rate is 115,200). or via LAN.
You will have a MUCH better experience connecting via LAN though.
Yes it’s good now with your setting congratulation thank’s F5PLS
Hello Mr.Brow, et al,
Happy to see that you also have an Icom R-8600.
The super-nice and helpful folks who developed this program have tried to help me out, but so far I haven’t been able to get the program running.
Will blame it on old age related problems.
Since you have an R8600, could I please bother you with
where to find all the correct settings the program requires, as:
Network Name
Network User Id
Network Radio Name
Password
etc.
I understand tat it is possible to pull up all of these, and any others required,
directly from the radio itself.
Where do I find each of the above ?
I should have done a better job on recording the ones that work, but
it’s been such a long time. Until recently, it worked. Then, a power glitch.
Thanks for the help, very appreciated,
Bob
@eliggett has already given you exactly the information you need in your thread asking for the same information.
